Thread: Any tips or info on how to take the lower seat bottoms apart?
    Have had the seat backs apart and put back together, now I'm starting to work on the seat bottoms any idea how this come apart?
    Apr 2011
    N.Calif., south of SF
    Its always best to state the year the parts/seat are out of.
    If you are referring to removing the seat covering, pressing down on the seat covering material allows the folded edges to come out out the metal grove on the seat pan. At first it often seems they won't come out but gentle persistence pays off. Some some carefully applied silicone lube helps.
    Having a helper or having some way of compressing the entire cushion or at least the whole front, side back etc is best. Just be very careful to not allow the cushion to rise while only part of the folded seat material is attached- this could lead to ripping and tearing of the seat cover material.
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Yeah sorry about that I talking about 1969 regular seats not sport seats.
    So if I understand you to swap out the seat bottom covering you simply compress the seat and then pull out the folded material.
    I assume you just repeat the process to install the new coverings, is that correct?
    Apr 2011
    Yes, correct. Again, just compress the seat cushion, ideally with a helper or sitting on it or some mechanical means. Slowly work your way around the edges. Sometimes the fold is rusted into the channel around the seat that makes for an exciting time. I found having the seat bottom facing upwards is best since one can see clearly the progress of the folded seat material coming out.
    BUT while you are there definitely replace at least the cushion material if it is at all worn, compressed or looking shabby.
    Hope this helps,
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
  1. WTB - Original seat bottoms for a '70 coupe
    By lexatola in forum For Sale: 911 Parts
    Last Post: 12-11-2011, 03:51 PM
  2. Parcel Shelf and Seat Bottoms
    By WCB4 in forum Technical Info
    Last Post: 05-10-2011, 05:07 PM
  3. FS early 911 rear seat bottoms
    Last Post: 01-29-2011, 07:58 AM
  4. WTB: rear seat bottoms & leather straps...
    By Kaleid in forum For Sale: 911 Parts
    Last Post: 03-19-2008, 06:14 PM
