Results 1 to 10 of 16
Thread: Engine overhaul-960029
    Nov 2006
    S. F. Bay Area
    Beginning engine rebuild and have discovered original (first edition) chain tensioners and aluminum chain ramps. That and the excellent condition of the motor leads me to speculate that this may have never previously been opened. What are some other 'clues' I may look for? (It does have the aluminum 'expandable' oil return tubes) which don't necessarily indicate complete teardown. Thanks.
    Brian
    S Reg #1032
    See if the back of the bearing shells have the Porsche logo and part number. Usually a rebuild will have aftermarket supplied bearings.
    "8G V" on original fasteners
    headmarks like Verbus, Inbus (search here for word "headmark")
    paint dabs on original fasteners
    original oil strainer screens
    Jul 2012
    Claremont,CA
    "We have the technology . We can build them bigger, faster, stronger"
    Mr. Goldman (six million dollar man)
    I could not resist
    Marge "porschegal"
    P.s. i have those bearing in stock
    CEO of the Best early 911 parts store in Southern California
    www.Schnellautosports.com
    Nov 2006
    S. F. Bay Area
    Quote Originally Posted by porschegal View Post
    Alas, apparently somebody agreed with you as I found .025 undersize bearings. The fasteners are correctly marked. Thanks.
    As they say, "It's only original once."
    Brian
    S Reg #1032
    Oct 2008
    Burford, ON, Canada
    Brian, while you have the engine apart could you provide some photos and other details of this very early 901/02 engine.
    Two things are important right now, the date codes form each half on the pulley end, and the casting #'s under the oil tubes. 901.101.101.01 changed to 101.02 about this time while 901.101.102.01 remained the same. I do not know if it is a coincidence with the new 901/02 engine or a change was required in some way. It would be ideal to document the actual differences in the case half. See thread:
    http://www.early911sregistry.org/for...case-Revisions
    Also the pairing # would be useful.
    Nov 2006
    S. F. Bay Area
    Attached are the numbers from the case: 960029, and 5316. Also, the oil pump is 5348. Where are date codes?Name:  911case2.jpg
    Brian
    S Reg #1032
    Nov 2006
    S. F. Bay Area
    Other case number:
    could not find anything on left side case. maybe because the left case half casting number is 901.101.101.02, and the right half is 901.101.102.01. Name:  911case1.jpg
    Brian
    S Reg #1032
    just out of curiosity do you still have the engine?
    Nov 2006
    S. F. Bay Area
    Yes. Case done. Heads done. Awaiting p&c's...
    BTW, this is not the original engine for my car.
    Is it yours?
    Brian
    S Reg #1032
  1. Replies: 27
    Last Post: 04-12-2023, 08:47 AM
  2. Is the fuel pump overhaul for 911 of 1973 possible?
    By naba901R in forum Technical Info
    Last Post: 12-27-2013, 10:40 PM
  3. Cylinder overhaul or new?
    By 67Porsche911S in forum Technical Info
    Last Post: 06-03-2009, 10:15 AM
  4. Engine Overhaul
    By 72911E in forum Technical Info
    Last Post: 09-25-2008, 11:29 AM
  5. How To: MFI Electric fuel pump overhaul
    By kenikh in forum Technical Info
    Last Post: 04-25-2008, 08:37 AM
