Results 1 to 10 of 11
Thread: Removal of 3M Yellow Glue??
    Aug 2006
    Chicago area
    Hey guys, what is the best product to remove that yellow hardened glue goo from 3M? I have tried mineral spirits and brush cleaner to very little success. I have a fairly large area to clean up. It is where a PO glued the rubber threshold onto the outer sill. There is a lot of glue residue on the rubber threshold and on the painted sill too, so I need something that won't damage paint.
    What does the collective experience here recommend? Thanks.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    Dec 2004
    SE Michigan
    Scott, have you tried a heat gun and a plastic scraper?
    Bill G.
    EarlyS #718 | RGruppe #437
    Apr 2011
    N.Calif., south of SF
    I found the 3M adhesive removers works well. They make several variants of this type of product. Also, using carefully the Googone style stuff can work but tend to be stronger than the 3M products.
    Sometimes leaving a saturated rag sit on an area softens, but again be cautious to not go too far and damage a surrounding area.
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Feb 2007
    Thousand Oaks, CA
    3M has an adhesive remover that comes in a spray can. I've used it several times in the past and works great without damage to the paint. Unfortunately I can't recall the specifics but 3M web site should have it listed. Never a fun project but always looks great when your done.
    Tom Ching
    69E Burgundy
    Dec 2008
    Woodland Hills, CA
    Rub in gently. Don't rub exessively. Let the product soak in and soften it up for removal.
    Aug 2006
    Chicago area
    Quote Originally Posted by 911scfanatic View Post
    Not unless I want to remove the paint (don't) or melt the rubber threshold (don't). Too aggressive.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    Dec 2004
    SE Michigan
    You won't remove paint with the heat gun, you Sally. If you hold it an inch from the paint at the highest setting...maybe.
    I've done it. I works in getting the bulk of it off, then follow up with the 3M stuff once it's soft and there's less of it.
    Bill G.
    Sep 2008
    Auckland , New Zealand
    I just used a crc product that is citris based for removal of sticker glue from products. Worked really well and better than having solvent smelling out the shop
    John Gausden
    Auckland, New Zealand
    (shipping carson,CA)
    Early911nz.org
    ST-Classic.com
    ST-Classic Facebook
    Aug 2006
    Chicago area
    Me Sally, you Polly... Thanks buddy - I will give it a try.
    Scott H.
    1969 Coupe LtWt
    1973.5 911T
    Senior Member mrgreenjeans's Avatar
    Nord Stern Region of PCA....west coast side of Region
    I have used the 3M stuff in the red can as Greg pointed out in post 5, and it does Work really well.
    Also had an old can of something called "PrepSol" I used to strip off old wax and pollutants, acid rain residue, tree sap, bird scat and such, on British and German cars that I used to buy and sell on. It would also work well on small patches of rubber windshield sealant and glue on rubber or paint with no damage.
    Don't know if this is still available or not......
    Best Regards,
    mrgreenjeans
    member # 1503
    -'68 -912 Red
    -'74 -914-2.0 litre - Sunflower
    -'82/83 -944 -M404 - Guards Red
    -'84 -944 -M456 - Guards Red -Weissach Prep. -H52
    -'84 -944 -M456 - Zermatt Silver
    -'84 -944 -M404 - Sunroof Delete - Ruby Red
    -'85.2 - 944 -M456 -Zermatt / Sport Purposes
    -'86 -944 -R74 Spt.Touring Pkg - White/Burgandy
    -'88 -944 - Jubilee Ltd. Ed. -Satin Black Met/Grey Plaid
    -'88 -911 - Tourist Delivery -Venetian Blue
    -'89 -944 Turbo M030 - Satin Black Met.
  1. Removing glue from 46 year-old vinyl
    By StephenAcworth in forum Technical Info
    Last Post: 04-13-2013, 06:58 AM
  2. Glue
    By Original Poster in forum Technical Info
    Last Post: 02-22-2013, 11:39 AM
  3. Glue on Schutz
    By IAA1963 in forum Technical Info
    Last Post: 05-09-2011, 05:37 PM
  4. 4 Piece Trunk Carpet and Glue
    By EsGeht in forum Technical Info
    Last Post: 06-22-2006, 09:51 AM
  5. Rubber glue (?)
    By John Fusco in forum Technical Info
    Last Post: 04-07-2006, 02:39 AM
