Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: decoding 915 gearbox numbers
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    there have been a few threads on decoding gearbox numbers. Most have been on the early ones; not the 915 ones.
    However this is what I think i have gleaned from books, threads etc on the codes for 915 boxes.
    There are 7 serial numbers describing the gearbox not including the type number.
    the first three all mean something and the last 4 are the consecutive serial ones for that type and year.
    so take 7 1 3 1234
    7 is the code for a 6 cylinder car - ie 911
    the second number is the gearbox type - see below
    the third number is the year 3 for 1973, or say 9 for 1979
    and the last 4 (1234 in this case) are the consecutive serial numbers of that type
    My query, after taking a photo of my number which makes it much easier to read than i have been able to do in the past is about the second number.
    My records show the following as decoding the second number:
    0 four speed standard ratio
    1 five speed standard ratio
    2 four speed sporto
    3 five speed optional ratios
    4 four speed optional ratios
    5 no record
    6 no record
    7 no record
    8 RS five speed with oil pump.
    I have always thought that my gearbox number was 713 1350. This is from reading the number on the box as i have never had confirmation from Porsche and it is not in my maintenance and delivery documents unlike the engine number, key number and chassis number.
    It is a 73 E build in June 1973 with chassis number 1306- ie almost at the end of the run of 1366: and in fact just over 95% of all coupes by number were built before mine if using the production number as a guide. It has had standard 5 speed ratios in it as long as i have had it (nearly 20 years)
    The production number (ie for 73 coupes of any sort built) is 89xx ie over 8900 coupes of the 9447 built that year.
    Obviously a fair number were sportos and a lot were 4 speeds , probably 1500 by then were RS's with an "8" gearbox and there were a number of optional ratio gearboxes. However IF my number is 1350, and is a standard box, and it is original to the car which is what i understand, going from my production number if they were assembled in rough order and targas were built at about the same rate as coupes, it would mean that less than 10% (maybe about 9%) had "713" gearboxes - ie standard 5 speed boxes.
    This seems to be in complete contrast to Australian deliveries for 1973 model year cars. Excluding RS and RSR's 91 cars were delivered here. of those 91 almost 50% (44) were 5 speeds, 40 were sportos and only 7 were 4 speeds. That has a lot to do with how cars were spec'd for Australia but it is a huge divergence.
    what has be thinking is this photo i took of the number today. The number is badly scraped, as many are due to where they are placed and the type number (which would help here) is completely missing. However the numbers in the photo have made me question all that i have believed about this in the past.
    Name:  gearbox number.jpg
    Knowing the first number is a 7 and having a 1 in the series, even though a lot is scraped off, to me the second number looks much more like a 7 than a 1. I think it SHOULD be a 1 but i am wondering if i am correct or maybe IF the numbers i don't have a record for (5, 6 and 7) were actually used in some gearboxes?? in addition the apparent low number of 5 speed standard boxes (assuming they are used in roughly the correct order) also puzzles me. I am going to check my databse of Australian cars (where i have gearbox numbers) to see if mine is out of sync with them or not.
    anyone have any thoughts?
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
    Dec 2004
    Melbourne Australia
    I have just been told by email that "7" is for a 915/03 box (thanks Ryan) ....and "6" is 925 sporto
    that makes a lot more sense both having a relatively low serial number on a late car and what the stamping looks like as well
    It would help if the type number had not been ground off
    however IF i have a 915/03 box i am even more confused - what is the difference in 1973 between a 915/02 or /01 and 915/03?? is it the material they are made from or something else - say ROW v USA. It does not seem to be the ratios as they, and the R&P seem to be the same as the standard 5 speed
    Hugh Hodges
    73 911E
    Melbourne Australia
    Differences:
    915/01: with oil pump, 4th gear ratio 26:25, shaved gears
    915/02: like /01 but with without oil pump, ground gears
    915/03: like /02 but with 4th gear ratio 26:35, shaved gears
    Instagram
    Twitter
    Here´s info from Tech spec book 1st edition (5/1973) for decoding the second number of ´73 transmissions:
    0 four speed standard ratio 4 sp, with oil pump and ground gears (915/10) 0001-5000 OR with shaved gears (915/11) 5001-9999
    1 five speed standard ratio 5 sp, with oil pump and ground gears (915/00) 0001-5000 OR with shaved gears (915/01) 5001 -9999
    2 four speed sporto 4 sp, without oil pump and ground gears (915/12) 0001-5000 OR with shaved gears (915/13) 5001-9999
    3 five speed optional ratios 5 sp, without oil pump and ground gears (915/02)
    4 four speed optional ratios 4 sp Sportomatic, T with carbs (905/21)
    5 no record
    6 no record 4 sp Sportomatic, T USA and E (925/00) 0001-2000 or S (925/01) 2001-4000
    7 no record 5 sp, without oil pump and shaved gears (915/03) 5001-9999 OR with ground gears (915/02) 0001-5000
    8 RS five speed with oil pump 5 sp, with oil pump and ground gears (915/08)
    9 4 OR 5 sp, special transmission with oil pump
    Mika
    1973 911T targa (9113510254)
    signal yellow & black
    M409 sportseats leatherette & corduroy
    M424 fuel tank 85 l with emergency tire
    M470 comfort equipment
    M473 front bumper steel with spoiler
    Here comes the Bible
    Instagram
    Twitter
    ... take two ...
    Instagram
    Twitter
    Dec 2004
    Melbourne Australia
    thanks guys
    that has helped a lot
    so it is a 915/02 with standard 5sp ratios and ground gears
    Hugh Hodges
    73 911E
    Melbourne Australia
    Has anybody managed to make damaged Mg-915 serial number readable?
    Mine is REALLY badly hacked and totally unreadable.
    My wife is a c.s.i. and she has promised to help with this , but as she normally deals with guns and stuff made of iron/steel or aluminum, Mg is somewhat unknown territory.
    The current plan is to use the same technique as for aluminum, possibly including x-rays followed by acid etching..? I don´t know any further details. Classified and all that..
    I´d really appreciate any info regarding this matter.
    TIA,
    Mika
    Quote Originally Posted by drmrfi View Post
    Don't tell me ...
    Instagram
    Twitter
    Quote Originally Posted by Biancaneve View Post
    Don't tell me ...
    Join the club!
    Name:  915 serial number.JPG
  1. COA Decoding help
    By Haig Haleblian in forum General Info
    Last Post: 10-13-2016, 10:38 AM
  2. Decoding Bosch R-Numbers
    By uai in forum Technical Info
    Last Post: 06-13-2012, 12:01 PM
  3. MFI Number Decoding?
    By Neunelfer in forum Technical Info
    Last Post: 10-11-2011, 05:27 AM
  4. Decoding the VIN
    By Silverbullit in forum General Info
    Last Post: 11-27-2006, 06:39 AM
  5. gearbox numbers
    By vdubjim in forum Technical Info
    Last Post: 03-26-2006, 07:16 AM
