Page 272 of 296 FirstFirst ... 172222262270271272273274282 ... LastLast
Results 2,711 to 2,720 of 2954
  1. #2711
    Member lilacrs's Avatar
    Jan 2003
    Seattle
    Participated in our last and very wet PCA autocross of the season. Many thanks to Brent Jones for taking great action shots of my car all season.
    Perry
    S Registry #326
    58 Glockler Speedster
    62 Roadster
    73 Carrera RS #0049
    95 993 C4 3.8
    14 Cayman
  2. #2712
    Aug 2011
    Eugene, OR
    Checked it for oil leaks. For the first time since I bought this car over 18 months ago, it was totally dry!! Success... so far.
    Seriously, pretty pleased with this. My '84 Carrera was dry over the entire 7 years and 23,000 miles I owned it. So I figured it could be done, was just hoping I wouldn't have to go all the way through the engine to do so.
    The last 3 leaks were the #8 bearing, MFI drive on the left cam, and exhaust rocker shaft on cylinder #3. No leaks after a good drive and up to temp, no leaks after sitting for several days.
    - Arne
  3. #2713
    Aug 2009
    SF Bay Area
    Waited to the last minute to prepare for a track day tomorrow at Sonoma Raceway (Sears Point). My son and I are both registered but have to share the same car so I am going to track the 356 along with the 911 and make my son drive it during half the sessions. We have 7 20 minute sessions. Should be fun.
  4. #2714
    Sep 2012
    Colorado
    Two days, really. Three days ago, a guy in an early 'Vette pulled up to me at a light and asked if I knew my brake lights didn't work. I didn't. Over the past two days, I learned all about the brake light system on a '69T. Starting at the ends, my John Audette bulbs both tested OK, but I found a broken fuse at position B6. Not blown, broken, so still sort of making contact. A tiny little 5A thing, I replaced it. Still no brake lights, though. I put the car up in air and checked the master cylinder wires; both seem OK. Both are grounds; apparently, they are for a switched ground circuit that controls a warning system for the early USA master cylinder (which circuit is not shown on my copy of the elusive '69T wiring diagram). I pulled the pedal board and checked power to the brake pedal actuator switch. OK. I tested the switch, and EUREKA; it didn't work! I pulled the switch and ordered a new one from Porsche, which came overnight. Before I installed the new switch, I rechecked the old one. @$%@#&%&. Now it works fine! Probably just some schmutz inside the switch that came loose with all the handling. I thoroughly cleaned the old switch and reinstalled it. Now the brake lights worked fine, but require a hard press. I pulled the switch again, tightened the adjuster screw, and reinstalled it. Voila! Now the brake lights worked perfectly. I then re-installed the pedals, pedalboard, and carpets. Done. What a PIA. I think I saved a small fortune doing it myself. So, does anybody need a brand-new Porsche brake light actuator switch? (Porsche used the same switch for a decade as the cruise control de-actuator switch).
    Rich Spritz
    1959 BMC Huffaker Mk1 Formula Junior racecar
    1967 Porsche 911 racecar
    1969 Porsche 911T
    1970 Winkelmann WDF2 Formula Ford racecar
    1973 Merlyn Mk24 Formula Ford racecar
    2007 Porsche 997C4 cab (totaled by an idiot running a stop sign)
    2014 Porsche 991 TurboS cab
    2019 Cayman GTS (wife's)
  5. #2715
    Aug 2012
    France
    Fixing a fuel leak - fuel pump replacement.
    Cheers
    O-G 26 - Early911S 2407
  6. #2716
    With some pointers from Jon B (thanks Jon!) I finally finished setting up the R&P backlash and side cover pre-load on my 901 box. Box is pretty much ready now
  7. #2717
    Apr 2014
    Germany
    Installed my new old steering wheel 👍
    1970 911 2.2 S Coupé Bahia Red - Early 911S Registry #3174
  8. #2718
    Aug 2009
    SF Bay Area
    Turn 3A last Friday
  9. #2719
    Thumbs up
    nice !!!..................
    Sep 2012
    Colorado
    Given that I have two early 911s, and I tracked my ‘67 911 racecar on Sunday, testing my new Garmin Catalyst. Last night and today I installed my John Audette Cibie BiIodes in my ‘69. The install was....um....not plug and play. But it worked, and caveat I still need to aim the things, I’m very pleased with the results, which are exactly as billed. Ignore the cross-hatching in the photo; that is a reflection. Rich
    Rich Spritz
    1969 Porsche 911T
  1. My COA came today....
  2. Looking at a '72 E today
  3. Today I am a happy man!
  4. Where is this car today?
  5. They came today!!!
