Thread: Sway Bar Mounting Question
    I just picked up a couple of rear sway bars and the mounting arrangement is quite unlike anything I have seen on a 911.
    It clearly doesn't use the ball pins on the rear trailing arms.
    Anyone seen these before?
    Aug 2007
    Phila Pa. area
    356 front sway bar.
    Mike
    Mike,
    Thank you. My 356 knowledge is seriously limited.
    They came with a pile of spares along with a very poor but complete and matching number 1965 car that has been 'updated' with a full SC Interior including dash, Impact Bumpers and SC flared rear wheel arches.
    The car is very early and pre-dates adjustable camber plates so it needs to go back to its original spec.
    We also found and bought a 1967 S (Right hand Drive) with the same conversion but by a different butcher.
  1. Cast Sway Bar Mounting Plates
    Last Post: 04-20-2013, 03:28 PM
  2. Replies: 5
    Last Post: 10-30-2010, 07:33 AM
  3. Hi/Lo horn mounting question
    By Cornpanzer in forum Technical Info
    Last Post: 04-22-2006, 02:10 PM
  4. Fender hardware mounting question
    By neilk in forum Technical Info
    Last Post: 01-30-2005, 06:11 PM
  5. Radio Mounting Question
    By MAPC in forum Technical Info
    Last Post: 01-20-2005, 09:18 PM
