Anyone have any ideas on the best method to close the hole, after the warm air intake tube is removed from the engine tin, to the left of, and below, the distributor?
Vic
Vic
Vic,
One method is to not fill the hole and not remove the foil hose at all....
Have the hose come up through the tin, compress it a bit, cap it,, clamp the cap, and call it a day....
I'm embarassed to post a picture after Chuck's, WOW.
But here is what's on my car top and bottom.
David...did you just 'find' those two round metal pieces?
Vic, No they were cut to size and then center drilled. They sandwich the engine tin. I think we put a piece of rubber as a gasket to keep vibrations down.
My 69E race car has a round piece of like thickness metal, held in place by a few little spot welds. Painted black to match.
Cheers, Ryan
Founder and chief centre cap remover at : ZOLLHAUS / Design driven custom PORSCHE : https://zoll.haus
ps. Chuck - where do I find one of those thumbs up stickers? Is it an oil brand?
Cheers, Ryan
I would like to see Chuck Miller's photos on reply #2. All I can see is a red "x". What am I doing wrong?
Andrew Chisholm
Early 911S Member #1994
1973 911E 2.4L Coupe
1969 912 Coupe, original owner
Andrew - Not sure what you're doing wrong... can you see any pics on the board? ... If not, you probably have to re-register on the board.
Ryan - The 'V' for victory hand sign is one of the logos for Kendall oil... I used Kendall GT-1 for over 30 years before I found out better... (see Kendall oil thread) I now have a BRAD PENN oil sticker in the same place.....
Here slightly closer... hope this helps
chuck nice engine compartment! which reminds me to clean mine up tonight..
marge
