Results 1 to 8 of 8
Thread: Rear Window Trim installation question
    Senior Member T308's Avatar
    Aug 2012
    So Cal
    My 68 came sans chrome window trim. I've got the pieces but I'm looking for help on the best way to install. Would it be best to pull the window VW style and mount the trim while the gasket is loose or install in place? Thanks for your help.
    Member #2419
    1960 356 Super 90
    1968 911 Normal
    1973 914 1.7
    1978 Ferrari 308 GTS
    Dec 2008
    Woodland Hills, CA
    Definitely one of the more frustrating do it yourself jobs. You will have to pull the glass and set the aluminum trim into the rubber seal while the rubber is inserted on the glass...then it's the ole rope install trick. It's easier with a new factory rubber seal. Good luck!
    Aug 2012
    So Cal
    Quote Originally Posted by gsjohnson View Post
    Thanks for the speedy reply. No wonder the PO left it off.
    Member #2419
    1960 356 Super 90
    1968 911 Normal
    1973 914 1.7
    Feb 2011
    Surrey, UK
    And if .... As seems to always happen to me .... some of the trim decides to come out of the rubber seal while you perform the 'old rope trick' then you might want to read the thread below. Hard to convey the euphoria ..... and the relief at not having to take the screen out again ..... that this little invention brought about.
    Good luck
    Mick
    http://www.early911sregistry.org/for...ighlight=Higgs
    P.S. both front and rear seals were Porsche OEM, so even that is not a guarantee of ease to the amateur.
    It has been my experience that the aftermarket seals make it very difficult to install the trim strips, especially in the corners. ALWAYS use original type seals.
    We tried two times to install a windshield with the customer supplied aftermarket rubber, (while he's watching) I then told him we will now use the genuine article, and of course it went right in! There is a DIFFERENCE !!
    Dec 2008
    Woodland Hills, CA
    Quote Originally Posted by T308 View Post
    Where in So Cal are you? I got a guy local to me who will come to your house if you need some help.
    Aug 2012
    So Cal
    Monrovia..
    Member #2419
    1960 356 Super 90
    1968 911 Normal
    1973 914 1.7
  1. Question on rear bumper installation ('67)
    Last Post: 11-03-2013, 09:02 AM
  2. Quarter Window Outside Trim Installation
    By JimVillers in forum Technical Info
    Last Post: 08-24-2013, 09:59 AM
  3. Replies: 8
    Last Post: 03-22-2013, 01:35 AM
  4. rear quarter window installation
    By julerb in forum Technical Info
    Last Post: 04-14-2007, 08:46 AM
