Results 1 to 10 of 13
Thread: 2.0 S Piston/Cyl group size question.
    Nov 2006
    S. F. Bay Area
    The original pistons have a very sloppy top ring just out of spe. Fortunately bought a spare set a few years back. However, 4 are size 5, and 2 are size 6. I see some overlap in the specs. Where is this measure taken, and how critical is it to the rebuild. As you know these p/c are quite difficult to source. Thanks, Brian
    Brian
    S Reg #1032
    May 2006
    CT
    Brian
    Measure the skirt diameter of each piston and the bore diameter (4 locations) of each cylinder. If you can pair the pistons and cylinders in a manner such that the piston to cylinder clearance for each of the (6) is less than 0.004", you will be good to go.
    Tom Butler
    1973 RSR Clone
    1970 911E
    914-6 GT Clone in Progress
    Nov 2006
    S. F. Bay Area
    Thanks, Tom. I'll do that. What I need to know is if I can install the spare p/c that are 4of group 5 and 3 of group 6. What does the 'group' reference and how do I measure it? Thanks
    Brian
    S Reg #1032
    Are you referring to the number in the triangle at the base of the cylinder? If so that is the height grouping. Although the actual height difference is very small (from memory maybe about a .001") you should keep the same heights on an engine side. What you are avoiding is putting a ever so slight deflection in the cam housing when it is bolted down.
    May 2006
    CT
    Here you go....
    Tom Butler
    1973 RSR Clone
    1970 911E
    Nov 2006
    S. F. Bay Area
    Thanks, gentlemen. Exactly what I was asking for. Now I can measure accordingly. With 12 p&c, I'll be able to get the right combo. Thanks again.
    Brian
    S Reg #1032
    May 2006
    CT
    Here is an example of a set I recently did for a customer.
    Tom Butler
    1973 RSR Clone
    1970 911E
    Banned
    Nov 2004
    Scottsdale, AZ
    Quote Originally Posted by tom1394racing View Post
    Brian
    .004" clearance? Hummm...
    That's quite a bit for an 80mm street set up.
    May 2006
    CT
    Porsche recommends a max allowable rebuild piston to cylinder clearance of 0.15 mm (0.006") for the 2.7 engine (see below). That would scale to around 0.005 " for a 2.0 engine.
    The common wisdom seems to be 0.004" max clearance.
    Tom Butler
    1973 RSR Clone
    1970 911E
    Nov 2006
    S. F. Bay Area
    Continued thanks. Tom, so in the chart for your customer's set I see 4 Height Grp 5 cylinders and 2 Grp 6. According to the manual I'm using, cylinder-to-case shims can be used in different thicknesses/multiples to achieve uniform cylinder heights. Is this advisable?
    Brian
    S Reg #1032
  1. a question for the group
    By robmog in forum General Info
    Last Post: 04-08-2010, 04:48 AM
  2. Fan size question - Carrera 6
    By v-8 in forum Technical Info
    Last Post: 06-21-2009, 10:49 AM
  3. Question on piston rings, 69 911S
    By NV Stig in forum Technical Info
    Last Post: 03-09-2009, 05:07 PM
  4. tire size question
    By RC70SCoupe in forum Technical Info
    Last Post: 03-19-2007, 08:54 AM
  5. Vintage Race Group question:
    By Homemade 911 in forum General Info
    Last Post: 12-20-2004, 08:08 AM
