Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Car non-start issue
    Jul 2009
    Vancouver, BC
    Car non-start issue
    Got a break from the rain today so decided to take the cover off the car, disconnect the battery tender and warm up the old girl...
    After letting the fuel pump run for a min then cranking for about 15 secs I stopped and waited another min. Starting again and it attempted to fire followed by a fairly loud backfire. Cranking again and it fired up on a few cylinders then a dull clunk and everything stopped. Attempting to start again and I only got a short "chug" sound from the starter motor without the crank turning over. It almost seems like the crank or something within is preventing the engine from turning over.
    Any ideas on what I might try to look for first?
    70E - 2.7L motor with MFI. Checked the electrical fuses, everything seems to look okay. Lights and fuel pump operating.
    Much appreciated.
    Marc C.
    1970E
    Put wrench on the crank pulley and see if you can manually rotate the engine a full revolution.
    Jul 2009
    Vancouver, BC
    Yeh, my gut feeling is that it's something mechanical, not electrical. I was actually thinking about that bit ran out of time and light tonight. will pull the plugs and try tomorrow.
    Marc C.
    1970E
    Feb 2011
    Surrey, UK
    Flat(ish) battery? Charge it up and see if that helps - after turning it over as Ed suggests.
    Mick
    Senior Member uai's Avatar
    Jan 2011
    Horb a.N. Germany
    Could be a stuck valve if you're not lucky.
    I agree manually rotating the engine two full revolutions. (carefully)
    Cheers
    Uli
    Pull out the starter, maybe the ring gear broke off some teeth. after pulling out the starter you may see it, if not have someone rotate the engine via pulley.
    take your pulley wrench and go counterclock wise a half revolution or more and proceed with starting the car. vapor lock I think its called... happened to me a few times.
    oh and dont leave the wrench attached to the pulley!!!
    Richard aka le Zookeeper
    early reg #1128
    Jul 2009
    Vancouver, BC
    Well I pulled the plugs but the crank is still stuck (fan belt just spins on the pulley. My worst fears are beginning to be realized - maybe a broken crank or other mechanical malady which occurred when there was a serious backfire while trying to start her up.
    Crap. Too far away from CA to have the builder took at it.
    Marc C.
    1970E
    Jul 2008
    South Florida
    Your description sounded more like hydro lock... but broken cranks also result from galling by oil starvation.
    Curious about what you find Marc, hope it's not the worst. Good luck.
    Russ
    ESR # 1537
    '62 356S Notchback Hotrod
    '67 S Das Geburtstagsgeschenk
    '68 T Targa Sportomatic
    '68 L SW Targa Sportomatic
    '70 914/6 GT
    Jul 2009
    Vancouver, BC
    Quote Originally Posted by Bullethead View Post
    I was hoping you were right about the hydro lock but the crank is seriously stuck and I'm running out of ideas. I doubt that oil starvation had anything to do with whatever the ailment is because I always had good pressure. Besides, I didn't even get the engine running when this occurred.
    I've had a devil of a time getting it started ever since I got the car last spring. Once warmed up, she ran and started great. Cold starts always required copious amounts of cranking and stabs on the throttle.
    Marc
    Marc C.
    1970E
  1. MFI warm start issue
    By Boulder Bob in forum Technical Info
    Last Post: 07-20-2020, 12:46 PM
  2. Cold Start MFI Issue
    By prez! in forum Technical Info
    Last Post: 01-20-2014, 03:51 PM
  3. Where to start?
    By gcdpetaluma in forum Technical Info
    Last Post: 07-25-2013, 02:51 PM
  4. 73 E won't start
    By cmcfaul in forum Technical Info
    Last Post: 06-11-2010, 02:27 PM
  5. MFI cold start proceedure w/ cold start disabled
    By Type911 in forum Technical Info
    Last Post: 09-22-2005, 11:41 AM
