Results 1 to 1 of 1
Thread: Rocker Panel Screws, Which Size Goes Where?
    Nov 2002
    Worshington State
    Am reinstalling the S wide rocker panels and recieved the screw kit from Stoddard. I wasn't expecting to see two different size screws, one very short and one not so. I was expecting the not-so's but where do the little stubbies go?
    After doing the math, I believe I figured it out - long ones on the top-most edge and shortys around the bottom and to secure the end caps.
  1. Bolt size for center rear license panel
    By merbesfield in forum Technical Info
    Last Post: 01-06-2014, 07:06 PM
  2. FS: @356Registry - Fender Joining Panel & Rocker Panel Support
    By mshaver51 in forum For Sale: 911 Parts
    Last Post: 03-16-2013, 07:42 AM
  3. Correct rocker panel finish
    By 2POINT7 in forum Technical Info
    Last Post: 06-15-2005, 03:54 PM
  4. Color under rocker panel
    By Justin in forum General Info
    Last Post: 02-08-2005, 12:05 AM
  5. Any particular screws to use for mounting rocker trim??
    By wolfturbo in forum Technical Info
    Last Post: 12-23-2003, 08:42 AM
