Results 1 to 10 of 14
Thread: Early SWB mirror locations
    May 2011
    Chelsea, Québec
    Hallo. I am looking to relocate the mirror(s) on my '66 coupe.
    They were replaced and moved in 1973 to look more modern (!).
    I have some Talbots en-route and wanted to have precise measurements of where to locate the receptor holes.
    The doors are early (I am not certain they are original, though they could well be).
    On the passenger side, there is no evidence of earlier holes filled and I have not dismantled the drivers door just yet.
    Can anybody help out here?
    Thanks!
    There are mirror bolt access holes on the inside of the door frame, so the mirror will go in that approximate position, however don't use those same holes on the passenger door for mirror position. That only works for right hand drive cars. The correct right side mirror position will have to be determined by sitting in the car while someone positions the mirror so you can see the right hand lane. The mirrors are NOT symmetrically positioned.
    Nov 2006
    S. F. Bay Area
    There are mirror bolt access holes on the inside of the door frame......The mirrors are NOT symmetrically positioned.
    Great tip. Especially true with the earlier cars with opening vents.
    Brian
    S Reg #1032
    I agree with Ed as regards to door mounting. Take a look at page 1 of Dr. Brett Johnson's Restorer's Guide to get an idea of where the passenger side Talbot needs to be mounted on the door (sure looks like it would interfere with the moveable vent window of a SWB car...) However, if you want a symmetrical look, Talbot mirrors can be (and often were) mounted on the fenders. Sit in the car and have the SO move the driver side mirror to an appropriate position (probably in front of the fuel door). Then see if the passenger side mirror works in the same spot on the other fender. Keep moving them around until both sides work for you. Lore has it that the factory used this exact procedure on some of the SWB race cars.
    Early 911S Registry
    Looking for engine 960 168
    Looking for gear box 103 165
    May 2011
    Chelsea, Québec
    That's a nice idea... anyone got any photos of this so I can use a reference point?
    thanks again!
    Sephen
    Quote Originally Posted by Flunder View Post
    I agree with Ed as regards to door mounting. However, if you want a symmetrical look, Talbot mirrors can be (and often were) mounted on the fenders. Sit in the car and have the SO move the driver side mirror to an appropriate position (probably in front of the fuel door). Then see if the passenger side mirror works in the same spot on the other fender. Keep moving them around until both sides work for you. Lore has it that the factory used this exact procedure on some of the SWB race cars.
    Oct 2010
    Stockholm/Sweden
    Here´s a reference Stephen!
    Name:  Side-mirror-close-up-in-rain-Porsche-911-at-the-Rennsport-Reunion-III-at-Daytona-International-S.jpg
    Porsche 935 DP1 Zirkelbach
    930/10
    Resale red
    Porsche 911, 1971
    2.5L on Webers
    Silvermetallic
    Aug 2010
    Colorado
    My 67 had the passenger side mirror dealer installed when the car was purchased. It's on the sales receit. Unfortunitly they installed it on the passenger door in the same spot as the drivers door. I can't see ANY part of the mirror frame let alone the actual mirror. When I have a passenger I tell them to feel free to use it as it's useless to me. If I ever repaint the mirrors will be moved.
    Quote Originally Posted by cmpski View Post
    That's a lovely '67.....more photos please!
    JEFF BRINTON
    ESR #1572
    1968 911N
    1974 914 2.0L
    2023 Macan
    SOLD - 1967 911N / 1968 911L / 1967 911N / 1969 912 / 1991 964 C2 / 2013 991.1 / 2008 987 Cayman
    May 2011
    Chelsea, Québec
    Beautiful car and wonderful colour: I hope to get my '66 back to looking that good someday soon... thanks for sharing!
    Senior Member beh911's Avatar
    Aug 2009
    Atlanta
    This picture is from a thread on the subject a couple months ago:
    http://www.early911sregistry.org/for...ht-Side-Mirror
    Name:  2 mirrors.jpg
    1969 S Coupe #761
    Early S Registry #1624
  1. Jackstand locations
    By Bob Harriman in forum Technical Info
    Last Post: 05-02-2012, 06:26 PM
  2. Correct early wire guide locations
    By oscillon in forum General Info
    Last Post: 02-03-2012, 05:44 AM
  3. serial number locations.
    By Dave Pugh in forum General Info
    Last Post: 03-28-2011, 01:35 PM
  4. early SWB oil line "pipe clamp" locations
    By Neil '67 911S in forum Technical Info
    Last Post: 07-29-2010, 01:29 PM
  5. jumping ID locations
    By Shawn in forum Membership Questions
    Last Post: 08-25-2003, 08:30 PM
