Thread: WTB: MFI Pump Gasket Set
    Looks like my MFI Pump is leaking some oil. Was wondering if anyone has an extra gasket set to sell or can advise where I can buy one. My motor is a 2,4T but I am assuming that all T E and S MFI pumps use the same gasket set. Thanks.
    Bet this guy can help:
    http://mfiwerks.com/
    Olin - Member #1375
    1972 911T
    Original
    Options added
    Here are some links to the part numbers for the Bosch MFI Pump and Regulator gasket seal kit:
    pump
    http://www.automotive-tradition.de/e..._Pumpen_en.pdf
    regulator
    http://www.automotive-tradition.de/e..._Regler_en.pdf
    Edit: Once inside the above two links, If you further click on the Package Leaflet link you will see an exploded diagram of the pump and regulator.
    I'm not sure where to buy but maybe you can find out directly from Boach:
    http://www.boschautoparts.com/Global/WhereToBuy
  1. 2.0L Intake manifold Gasket
    By Norm01 in forum Technical Info
    Last Post: 03-08-2016, 12:27 PM
  2. Engine Rebuild - Gasket Set
    By Red Car in forum Technical Info
    Last Post: 06-06-2013, 08:38 AM
  3. 915 Oil Pump gasket question
    By MoparBoy72 in forum Technical Info
    Last Post: 06-21-2012, 09:07 PM
  4. Gasket Source
    By 50/50 in forum Technical Info
    Last Post: 11-05-2011, 04:29 AM
  5. MFI Gasket Set?
    By A.T. in forum For Sale: 911 Parts
    Last Post: 03-08-2011, 06:18 AM
