Replacing the headlight switch in the 73 911S. Does anyone have a headlight switch wiring diagram/schematic? I want to make sure I have properly moved the wires from the old switch correctly to the new switch.
Haasman
Haasman
Haasman
Registry #2489
R Gruppe #722
65 911 #302580
70 914-6 #9140431874
73 911s #9113300709
Should be able to find what you need here
http://www.pelicanparts.com/911/911_..._CIS_Part1.jpg
and
http://www.pelicanparts.com/911/911_...l_diagrams.htm
Thank you for the links and the pictures.
Haasman
Haasman
Registry #2489
R Gruppe #722
65 911 #302580
73 911s #9113300709
Question- Is the 73 wiring at the headlight switch any different than the earlier cars, such as on the links provided?
Haasman
Haasman
Registry #2489
R Gruppe #722
65 911 #302580
73 911s #9113300709
Small difference. First diagram is '71, second is '73. You can see the additional wire, Bk/Rd to the emergency flasher(33) with a resistor(96) where it changes to a brown wire. You can see it in my previous post showing my 1973.5T switch.
That seems to be it. Thanks. I've obviously have one of the wires in the wrong place. When the headlight switch is on the brake lights come on!
I'll double-check again.
Haasman
Haasman
Registry #2489
R Gruppe #722
65 911 #302580
73 911s #9113300709
Make sure and disconnect your battery when working on the switch
Yes, always good to be reminded. Seeing how that heavy red wire also reminded me. One weird thing happened: I disconnected both batteries, usually fold the braided ground wire under the metal battery hold-down bracket. I noticed the truck light still on .... it seems the metal hold-down bracket will conduct electricity. Not going to do that again.
Still working on the correct locations for the wires on the switch. Can't figure out why the brake lights came on with when the headlight switch on......
Haasman
Haasman
Registry #2489
R Gruppe #722
65 911 #302580
73 911s #9113300709
