Results 1 to 2 of 2
Thread: common pressed steel?
    Jul 2012
    Kent, UK
    is this chalked section a common pressing from 64 through to 89?
    Rich
    68 911S
    mbr. 2393
    Dec 2004
    SE Michigan
    I believe it's only available as an entire panel from Porsche. But, let me know if you find out differently.
    Funny, I've got a similar patch on my car. You should find some nice rot behind that repair as well.
    Bill G.
    EarlyS #718 | RGruppe #437
  1. Replies: 11
    Last Post: 09-15-2013, 04:28 AM
  2. Bet this is common knowledge...but
    By speedo in forum Technical Info
    Last Post: 05-28-2013, 08:58 PM
  3. Replies: 1
    Last Post: 05-19-2008, 09:07 AM
  4. How common are gears for the 901 (by letter)
    By kenikh in forum General Info
    Last Post: 08-29-2006, 06:55 AM
  5. How common is factory Porsche overstamping on parts?
    By 911split in forum Technical Info
    Last Post: 09-05-2004, 04:59 AM
