Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Wheel Offsets for 2.8 RSR and Braid BZ Wheels 9 and 11 x 15
  1. #11
    Jul 2012
    Annapolis MD
    Thanks Kaefer .... Its not a super ture rsr clone but I would like to to be close with out breaking the bank, well atleast not too much. The interior will be fairly close along with the exterior bits The few upgrade from the 73 chassis that are on my 86 will stay except the sunroof. The 3.6 plant will take a little bit away from the classic look. I might have missed this but what is the overall dia of the mich TB's .. 23, 24, 25 inch? The avons that Roger had also had the same rear tire but in a 24 inch size instead of the 25 inch. The avons dont seem to be as hard to get vs the mich TB's. If you wernt so far away I would have driven down to VA and checked out your build.
  2. #12
    Port Macquarie, Australia
    Michelin measure their TBs metrically...
    For example, 18/60 means 18cm tread width and 60cm diameter (conventional measuring has them as 215/55 15)
    Here's the Braids on a local mate's car
    John Forcier
    EarlyS #1987
    Restoration Saga
  3. #13
    Jul 2012
    Annapolis MD
    John, thanks for the break down. For the life of me I couldnt figure out the 29/61 relationship. It all makes sense now. Your mates car ... hes running 10 or 11 inch braids for the rear? I need to message him and see how hes like the braids after the fact.
  4. #14
    Pretty sure they're 9" and 11". Alistair recently went to a lot of trouble to get them refinished perfectly as they were black centred.
    Go over to Pelican, he's Quozl on there http://forums.pelicanparts.com/members/105170.html
    John Forcier
    EarlyS #1987
    Restoration Saga
  5. #15
    Old post, I know. But for anyone researching wheel fitment the car from Pelican - quozl's, car is actually wering 15 x 8 and 15 x 10 Braid wheels.
    Edit: i found another post stating 15x8 and 15x11.
    Not sure which, i may contact the owner to clarify.
  6. #16
    Apr 2013
    San Diego, CA
    Old thread, but I'm wondering if anyone has tried out the RSR offsets (ET+3 front, ET-27 rear) in 17x9/17x11 wheels (standard 911 hubs/trailing arms)?
  7. #17
    Nov 2002
    Fremont, CA
    Per a post by JeremyD on this thread, (and another I can't find right now)
    http://forums.pelicanparts.com/porsc...-17-fuchs.html
    17x9et+17
    17x11et-8
    ...will work on a 911 w/ 930 flares (and 911 suspension). He stated somewhere else that 9et+12 would probably work in front, I believe. I would shoot for these +- 5mm offset and you should be quite alright.
    scott kinder
    kindersport@gmail.com
    Registry #614
  1. FS: NIB 15x11 Braid/Fuch rims
    By Jimmy18E in forum For Sale: 911 Parts
    Last Post: 09-08-2013, 06:51 PM
  2. Braid 7R offset question.
    By jameshtaylor in forum Technical Info
    Last Post: 11-28-2012, 08:46 PM
  3. Replies: 3
    Last Post: 05-05-2010, 02:42 PM
  4. Source for cloth braid oil breather line?
    By Cornpanzer in forum Technical Info
    Last Post: 08-29-2008, 01:00 PM
