The current discussion in the For Sale section regarding RS#056 has left me wondering about a general procedural question regarding Porsche, engine case stampings, and factory replacement cases.
Obviously Porsche supplied blank cases to customers over the years. Obviously not all of the factory blanks have been used as they keep popping up from time to time. So, what happens when someone purchases a blank case from Porsche and transfers all their engine's guts over to the new case?
It's been my understanding that the new, blank case was supposed to be stamped with the car's original engine number and the original, damaged engine case disposed of. It's my understanding that when this work was performed by the factory a *Z* or an *AZ* was added to the number to indicate a replacement (I can never remember). However, if the work was carried out by an independent shop or dealer, a number of things may have happened:
1) The engine was restamped with the original number, but the stamps' font would be incorrect
2) The engine was restamped with the original number in the correct font, but no indicator was added to the case number to identify it as a replacement
3) The case was not stamped at all and left blank even though the original case was disposed of
4) The case was left blank and the original case was not destroyed but, instead, provided with the car and documentation blah blah blah
Obviously, there are a number of possibilities as to how this scenario would play out, but my question is more of "what is acceptable"?
FACT: Replacement cases happened.
FACT: Blanks still exist.
So, if you look at the landscape of our hobby from a card player's perspective I guess you could say that blank replacement cases are wild cards.
But the question then becomes: "How do you play the card?"
In the specific case of RS#056 I'd say that there does not seem to be clear intent to defraud, but the situation does raise valid points about raking people over the coals for having a re-stamped engine case in the car. I suppose what I'm looking for is a general barometer of what people consider to be acceptable and where the line is drawn. Who knows, maybe #056 lost #5 and holed the case which was replaced with a blank and stamped with the original number before replacement. Maybe all the guts of the engine are original to the car.
Only The Shadow knows...
