Results 1 to 7 of 7
Thread: Removal of pedal cluster
    Nov 2010
    Harleysville, PA
    Can anyone give me a tutorial on the steps to remove a pedal cluster from an early car, or point me to a thread?
    Mark
    1967 911S - 306465
    1980 911SC
    2005 Carrera Cabriolet
    Dec 2004
    SE Michigan
    Pelican has lots of threads on the topic. Easiest to go there for basic, run of the mill R/R stuff.
    Bill G.
    EarlyS #718 | RGruppe #437
    Aug 2007
    Phila Pa. area
    Get under the car and look around, get in the car, go down where the petals are and look around. Take off approx 4 nuts, and the clutch cable and lift it out.
    Mike
    Dec 2004
    SE Michigan
    ...and accelerator cable.
    Bill G.
    when you are looking around under the car make sure to remove the steering rack protective plate so you can access the master cylinder and see two out of the four nuts that Mike mentions in the post above.
    Nov 2010
    Harleysville, PA
    Thanks to all. The last clue from Nick will help but now I have to get the plate off!
    Mark
    1967 911S - 306465
    1980 911SC
    ... Helps to soak fasteners with penetrating oil (PB Blaster is my favorite). Tap nut flats with brass drift helps to loosen years of thread bonding.
    John Schiavone
    Connecticut
  1. pedal cluster removal
    By Bob Harriman in forum Technical Info
    Last Post: 11-24-2013, 09:15 AM
  2. Pedal Cluster
    By hoffman912 in forum For Sale: 911 Parts
    Last Post: 03-08-2012, 06:28 AM
  3. Pedal Cluster
    Last Post: 11-21-2010, 05:59 AM
  4. pedal cluster check
    By 356robo in forum Technical Info
    Last Post: 05-29-2010, 09:54 AM
  5. '68 Pedal Cluster Fun
    By Fritter in forum General Info
    Last Post: 11-27-2009, 04:48 PM
