Thread: Carburetor Stud Size?
    Port Macquarie, Australia
    Happy Holidays All
    I have a set of PMO manifolds that are missing the studs to bolt down my weber carbies... Can anyone help me with the size? I presume M6, but how long - and where do I get them?
    Cheers
    John Forcier
    EarlyS #1987
    Restoration Saga
    Senior Member CamBiscuit's Avatar
    May 2006
    Adelaide, Australia
    Not sure about length mate but make sure you run the phenolic spacers which I think require longer studs than standard.
    Looking for engine # 6208151
    '74 RS 3.0 Replica
    '70 911E Bahia Red (SOLD)
    '71 911 S/T Replica 2.3 Twin plug BEAST (SOLD)
    Australian TYP 901 Register #78
    Early S Registry # 1076
    Yep, got the spacers sorted - it's the other end - where the manifolds and carbs meet...
    John Forcier
    EarlyS #1987
    Restoration Saga
    Jan 2003
    UK
    The manifold --> carb studs are M8 x approx 40mm
    They should be readily availalble (doesn't matter if they're slightly longer) - eg www.youroil.net (who are an online retailer for PMO/Weber parts)
    Andy
    Early 911S Reg #753
    R Gruppe #105
    Thanks Andy, much appreciated!
    John Forcier
    EarlyS #1987
    Restoration Saga
    A quick update in case this ever helps anyone...
    The original studs that are removed from the heads for the taller/longer PMO supplied studs to allow the phenolic spacers to be fitted are M8x40mm; so they have been cleaned up and reused for the studs that bolt down the carbies to the manifolds.
    Cheers
    John Forcier
    EarlyS #1987
    Restoration Saga
  1. Help w/ Wheel Stud Identification
    By 914-6gt in forum Technical Info
    Last Post: 01-09-2014, 07:03 PM
  2. Correct wheel stud size for 1973 911T coupe?
    By Paul-HB in forum Technical Info
    Last Post: 06-17-2013, 12:46 PM
  3. Stud Farm
    By Reza in forum General Info
    Last Post: 06-24-2011, 09:34 AM
  4. 911 R Carburetor Help
    By s2guy in forum Technical Info
    Last Post: 04-23-2010, 09:53 PM
  5. Loose stud or stripped lug nut
    By denson in forum General Info
    Last Post: 11-10-2008, 04:52 PM
