Results 1 to 7 of 7
Thread: Aluminum dash trim
    Banned
    Nov 2012
    The OHio
    Aluminum dash trim
    I picked up a complete original set of aluminum dash trim so that I can put the original radio back in my 911
    One of the pcs has a small crease............is this something that can be rolled out or is there another way to do it. Its not too bad and Im not even sure if it will notice when installed.
    Thx
    chas
    You won't do any harm by attempting to roll out a crease, keeping in mind that the piece in question must be pristinely clean front and back, as must the flat surface you are rolling it out on, and the roller surface as well. It it was me, I'd try something like a very hard rubber roller with handle used to press down contact cemented plastic laminate. As a surface, the machined table of, say, a bandsaw, tablesaw or the like would work. Depending on the damage, unlikely you will get it perfect-perfect but worth a try...............................................
    Banned
    Nov 2012
    The OHio
    Thanks Sabby
    Also any thoughts on getting the finish consistent, the area that had an old radio faceplate etc etc is a different color/patina than the rest of the panel.
    Thx
    chas
    Dec 2008
    Woodland Hills, CA
    Maybe this will help. I ended up buying this aluminum dash facia set from Marek instead of mudeling around trying to save the original pieces.. Absolutely perfect reproduction in every regard.
    http://www.early911sregistry.org/for...hed-dash-facia
    Angustami---That could be more of a challenge.....The above suggestion might be a good one as if the piece has color variation due to exposure and age you would likely need to strip the anodization and re-anodize ---. Have you tried to aggressively clean the pieces? By that I mean the use of a "Dobie" pot/pan scouring pad (NOT a Scothbrite type pad -- only the Dobie-It won't scratch the surface) and a good household cleaning product like 409. Spray the 409 on all the pieces laid on flat on a table, let soak for a couple of minutes and scrub with the Dobie. Regardless if it works or not, you won't harm the surface. BTW, I have used this method on everthing from car parts to upholstery, to furniture, bare wood or not, for years with great results.... completely non-invasive.
    Banned
    Nov 2012
    The OHio
    Im on it shabby
    thx
    chas
    ..................That's "Sabby", but I have been known to be slightly disheveled on occasion!
  1. WTB: aluminum dash trim for 67s.
    By cdodd in forum For Sale: 911 Parts
    Last Post: 05-31-2014, 06:06 AM
  2. FS: Aluminum Dash Trim – Dash Fascia – From a ’71 911
    By m1franck in forum For Sale: 911 Parts
    Last Post: 11-05-2013, 11:30 AM
  3. FS: LWB dash aluminum and basketweave trim
    By blucille in forum For Sale: 911 Parts
    Last Post: 01-03-2013, 02:03 AM
  4. WTB: '67 Aluminum Dash Trim
    By jaudette3 in forum For Sale: 911 Parts
    Last Post: 08-05-2008, 09:36 AM
  5. Aluminum dash trim
    By NickP in forum Technical Info
    Last Post: 01-22-2008, 04:46 AM
