Results 1 to 9 of 9
Thread: Early CV Axels
    Early CV Axels
Size:  170.6 KBName:  911 017.JPG
Size:  172.4 KBName:  911 016.JPG
Size:  170.8 KBName:  911 003.JPG
Size:  169.9 KBName:  911 024.JPG
    Anyone have info or ever used these axels? Taken from a 1968 911L.
    Restoration newbie.
    Jun 2007
    San Francisco
    You might want to check the transaxle for a LSD, Nadellas were discontinued before 68 except for LSD cars.
    Plenty of info on here, search "Nadella"
    andy
    67S in pieces
    EarlyS: 1358
    [SIGPIC][/SIGPIC]
    Unless you are doing a historical detail correct, concourse perfect garage queen...ie never driven. Replace the Nadellas with later constant velocity joints. It's a pain as you have to change out the transaxle flanges, and I'm sure someone will chime in that they have driven on these relics for a zillion miles without a problem....they're lucky. They will fail, and if at the wrong time will steer you off the road or worse. Why do you suppose the factory replaced them early in the series?
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
    Aug 2009
    SF Bay Area
    Quote Originally Posted by ajwans View Post
    andy
    Very good point, Andy!
    A picture of one of the output flanges on the trans will reveal whether the car has a LSD or not.
    Flycut, please post a picture of the flange and we can ID the diff for you.
    Jim
    Dec 2008
    Woodland Hills, CA
    I have a 10/67 68 911 Normal and mine is not equipped with Nadellas. Might be worth more as scrap...
    Jim
    I Sold the Motor and Trans about a year ago to a friend who has them both in storage.
    May 2005
    Oroville, CA
    Give them to the guy with the trans and forgetabout it.
    H
    I was going to get the trans back and put it in my 69.
    What are the advantages of LSD?
    Aug 2009
    SF Bay Area
    Quote Originally Posted by flycut View Post
    First of all, if it does have a LSD, you won't be able to mate up your axles without a complex adaptor, made by a talented machinest/fabricator. If it doesn't have a LSD, you will need to find a pair of output flanges from a early 69 aluminum cased trans. That is asssuming that the trans is a 68. If it is earlier, all bets are off.
    Jim
  1. Replies: 8
    Last Post: 09-14-2013, 05:31 AM
  2. Replies: 5
    Last Post: 12-18-2012, 07:47 AM
  3. Replies: 6
    Last Post: 11-23-2012, 10:57 AM
  4. Nadella Half Shafts (axels) for SWB LSD
    By Rennman in forum For Sale: 911 Parts
    Last Post: 07-29-2010, 08:19 PM
  5. FS: early rear seat belts, early Behr engine oil cooler
    By Noah in forum For Sale: 911 Parts
    Last Post: 10-26-2005, 12:33 PM
