I am putting a set of fog lights on my 72E and am looking for a wiring schematic if one exists for the switch. The terminals are labed 1,2,3,K(?). I think #1 is for the bulb in the switch. Can someone tell me what the other terminals are for. TIA
Craig Williams
Eugene,OR
Member #1070
1972 911E Targa Puck
I would be interested in the answer to this question as well. Also where exactly does the fog light switch go, mine is a '70 so don't know if that is different than a '72?
Im not certain about the year differences for fogs. they have wiring diagrams over on Pelican. my best guess,
check the second relay from the bottom,.. left of the driver battery box.( if its still stock there is 4 relays in a vertical position). that is where fog lamps are routed to from the front of the car.
you should be able to trace the wire colors from there up to the dash. there should be a supplemental diag for the fog/auxl options in the factory manual diagrams also found on Pelican.
Richard aka le Zookeeper
early reg #1128
Richard thanks for the information regarding the Pelican site. I will give that a shot.
There is already a wiring harness provided by the factory from the fuse panel to the lights. I made a harness for the run between the switch and the fuse panel/relay area. Since the car did not come with fog lights I also needed to add a relay.
My main question deals with wiring the switch. For the MY 1972 the fog lights should only work when the low beams are on so one wire from the switch needs to be hooked up to the low beam fuse. I think that terminal #3 on the switch is for the bulb that lights the switch. I read somewhere the K termunal is for the dash illumination control feature but am unsure what wire feeds it. So I am a little confused which terminal on the switch is for ground and witch terminal feeds into the relay.
Here is how the car looks now, just need to put on the new fog light grills I got today (thanks Eric) and finish up the wiring.
Craig Williams
Eugene,OR
Member #1070
I meant to post to this thread, but ended up posting on an old thread.
Happy New Year.
http://www.early911sregistry.org/for...ch-Wiring-Help
http://www.early911sregistry.org/for...l=1#post561551
Craig,
Where did you buy your fog light switch? Looks perfect.
Chris
repops , in production , right is original, preview
I bought my switch from a fellow member Peter his handle here is pkg911. I was very impressed with the switch also. I wanted to thank Richard and ESULLY for the help links. Here is the finished product. Now I just need to figure out how to get a set of 7R's for the rear.
Craig Williams
Eugene,OR
Member #1070
