Thread: 911 2.0 FIA n°183 rules Period F
    Hello,
    I have just baught a 911 chassis # 303520 from december 65 or january 66 and looking for informations about FIA homologation n°183 for period F :
    I know I have to have Solex carbs but can I use :
    - 2.0L 69S heads single plug with large valves and port 36mm, 35mm and as fitted in the 906 (twin plug, port 38mm, 38mm)
    - 81mm pistons HC
    - cams : Solex cams without modifications, Solex cams mod by DRC or cams of my choice ?
    Thank you for your help
    Senior Member RennTyp's Avatar
    Apr 2006
    Oxford, UK
    In answer to your questions:
    1) no, you cannot use big valve heads. You have to stick with the 65 spec small valve sizes. This, more than the Solex carbs, is the real limitation on the power you can get out of an FIA 2 litre.
    2) yes, you can go 1mm overbore and stay within the regs. Compression ratio is free.
    3) yes, cams are free and you can use anything you want. Some people use 906 spec but that doesn't necessarily make for the quickest lap time on circuits that require torque out of slow corners.
    Early 911S Registry #888
    RennTyp,
    Your answers are very clear.
    Thank you
  1. New F1 culture/rules
    By Kris Clewell in forum Other Car Cultures
    Last Post: 03-26-2014, 10:12 AM
  2. 2014 DP Rules
    By sithot in forum Off Topic
    Last Post: 11-13-2013, 05:20 AM
  3. F1 2009 rules changes
    By Mark Morrissey in forum Off Topic
    Last Post: 02-17-2009, 11:36 AM
  4. Forum rules...
    By Chuck Miller in forum General Info
    Last Post: 08-04-2006, 03:09 PM
