Thread: remove indicator switch
    Jul 2010
    Lisboa, Portugal
    Hello.
    It is possible to remove only the indicator switch without the wiring?
    I need to restore the switch but dont want to remove all the wiring assembly.
    Thank you
    José
    José Albuquerque
    1970 911 2.2 T Targa
    Aug 2009
    SF Bay Area
    You could cut the wires and leave them in the car. Reinstalling the switch would take just a few hours or days depending on your skill level(if you didn't set your car on fire in the process) or you could just remove the switch with the wiring (it takes about 30 seconds more time than using a pair of cutters). Re-installation will take anywhere between 5 and 30 minutes depening on your skill level. The choice is yours................
    Jim
    Jul 2010
    Lisboa, Portugal
    Thank you Jim.
    I already installed a batery cut for these little adventures
    José Albuquerque
  1. FS: a few tail indicator lenses and one front indicator lens
    By fourteenten in forum For Sale: 911 Parts
    Last Post: 04-09-2014, 08:32 AM
  2. Hi beam indicator on 73 E
    By cmcfaul in forum Technical Info
    Last Post: 03-30-2012, 10:45 AM
  3. Remove headlight switch
    By albuquerque in forum Technical Info
    Last Post: 11-12-2011, 03:29 PM
  4. WANTED: indicator stalk/switch etc suit 1970 911
    By obrut in forum For Sale: 911 Parts
    Last Post: 11-01-2006, 04:53 AM
  5. Indicator (Signal) Switch
    By CamBiscuit in forum Technical Info
    Last Post: 10-07-2006, 12:07 AM
