Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: H4 headlights? Good idea?
    Just looking for some opinions on H4 headlights.
    Are they a good idea, style wise what is everyone's opinion. It is my understanding they were standard in Europe, but because of goofy US law they were not and are not legal here.
    Jul 2006
    Corvallis, OR
    They look good and are priced right. If you want to spend more money then you can get some H1's but H4's work great.
    72S, 72T now ST
    What is the difference between the H1's and H4's?
    about $600
    1968 SWB Coupe
    Polo Red
    Member # 2469
    Sep 2006
    La Quinta
    I like the H1 units. The high and low beams can be adjusted separately.
    1962 356 Cab, show car, sold.
    Registry #983
    R Gruppe #741
    H1 vs H4
    Quote Originally Posted by Eli View Post
    . . . What is the difference between the H1's and H4's? . . .
    H4s are the current European-issue non-sealed beam lights . . . use a big bulb inside of a separate big-a$$ single reflector behind this cool-looking fluted glass
    H1s are an earlier kookier version . . . similar to the H4s except that the low-beam and high-beam use separate bulbs + reflectors. Used on Euro cars 'till the early '70s (?)
    Expensive, weird, not that great to use . . . . but totally bitchin' bits if you can find them + afford them . . . . + get them to work
    WAY more, here --- see post #135 . . . .
    http://www.early911sregistry.org/for...ten+fifty-nine
    . . . Good idea? . . .
    Depends
    My car came w/ H1s so --- that's it . . . end of story. But a lot of cars have 'European-style' lighting added --- 'cause it really changes (for the better, IMO) the face of the car . . . usually w/ H4s. Plug-&-play
    So, if you're adding Euro lights to a car? . . . H4s look virtually identical to H1s --- and will give you the 'look' that I think you're interested in . . . but are currently available + affordable. H1s went out-of-production about four decades ago, so . . . . sourcing is problematic. +Co$t
    HtH
    Yeah, I'm fine with getting H4s.
    Since my car is a US car anyway I will just keep the sugar scoops on hand. I can't justify the extra expense since really the "correct" lights would be sugars.
    Thanks for the help.
    Feb 2010
    San Francisco, CA
    I think you'd be hard pressed to find someone that thinks the sugar scoops actually look good.
    H4s are totally the way to go, unless as mentioned you want to $hell out some cash for H1s.
    Hope the car is coming along!
    E911SR & RGRUPPE
    '73 S Coupe #306
    I agree.........sugur scoops look IMO
    1968 SWB Coupe
    Polo Red
    Member # 2469
    My car is coming a long it has been a long haul. The missing MFI pump was hard as hell to find, not many out there for a 1969 911 E, and even harder to find one that ends in 006 and is in great shape.
    I paid through the nose for my pump, but it is in great shape and is ready to go. Just needs to be put it on and add few fuel lines swapped out and I should be a lot closer. It was missing a micro switch as well, so tracking that down.
  1. webasco heater: good idea or fire hazard?
    By rower in forum Technical Info
    Last Post: 01-02-2014, 12:16 PM
  2. back dating guards - good idea / bad idea
    Last Post: 10-24-2012, 04:07 PM
  3. WTB: Good condition SWB glass US headlights
    Last Post: 12-03-2008, 01:42 PM
  4. Good Bosch Twin H1 headlights for 73RS
    By davidppp in forum For Sale: 911 Parts
    Last Post: 01-20-2006, 08:39 AM
  5. Good idea or bad idea....MSD unit for 67S?
    By Sacto S in forum Technical Info
    Last Post: 12-13-2004, 07:22 AM
