Thread: Steering column question
    Aug 2010
    Colorado
    How do I get this part off. I need to get the turn signal and windshield stocks out and the cover off. I'm stuck.
    If it makes a difference the car is a 1967S.
    Chris
    Unbolt that u-joint sticking out from the mast jacket, then find the allen head bolt on the right side of the switch housing and remove it, now you can rotate the clamp opening towards the driver side until the clamp split lines up with a locating pin that will fall out. Now pull the entire housing towards the interior.
    Aug 2010
    Colorado
    Thank you!
  1. Steering Column Bush
    Last Post: 12-04-2013, 08:17 AM
  2. WTB: 911 Steering column column cover (LWB)
    By RSwannabe in forum For Sale: 911 Parts
    Last Post: 04-22-2013, 07:25 AM
  3. Quick Electrical Question: Wire-steering column
    By Haasman in forum Technical Info
    Last Post: 03-23-2013, 01:04 PM
  4. Replies: 3
    Last Post: 02-09-2013, 04:06 PM
  5. SWB Steering Rack, shaft up to the steering column
    By hoffman912 in forum For Sale: 911 Parts
    Last Post: 01-12-2012, 07:11 PM
