Thread: LAST STASH OF VINTAGE EARLY 911 PARTS. NOS trans gears, seals, cams, S rods, etc.
    Very last of my vintage 911 stuff.
    VIEW ALL PHOTOS HERE: PORSCHE PARTS Photos by velocejoe | Photobucket
    Alot of people want alot of this stuff, but no one seems to want to pay. I take Paypal. I have been a 100% positive feedback Ebayer for over ten years.
    It's really simple. Tell me what you want, send me your private email addy, or call me, paypal me, and it's yours. Don't know how else to put it.
    GEAR SET(901 5 SPEED 1967 TRANSMISSION I BELIEVE): Most NOS never used. See photos showing no wear: Been in a box for a while.
    Description by number: Will sell entire lot for $450.00
    1: Needle bearing. Not sure which gear this fits. $$$???
    2: Guide sleeve. Not sure which gear this fits. Marked H 72 3. Had a tag reading 1967 911 901. $$$???
    3: 3rd gear. 23/29 “N” 901/914 1.26. Marked X CNT on small gear. 4K II N3 on big gear. $95.00
    4: SOLD!!!!!!! 19 tooth gear. Marked with H inside a circle IH 3072(the 2 looks like a backwards S)
    5: Throwout bearing? Marked BCA 98 $$$???
    6: 22 tooth gear(complete). Marked with H inside a circle IMA 3AA(the AA is actually two arrows pointing up) $95.00
    7: 29 tooth gear. Marked 1 H inside a circle 68 II M 4. $95.00
    8: 28 tooth gear(complete). Marked 10 H inside a circle 69 XI. $95.00
    9: SOLD!!!!!!32 tooth gear(complete). Marked 12 H inside a circle 67 IIH 3042
    10: 36 teeth on dog ear. Not sure what assy this is. No markings. $95.00
    TRANSMISSION PINION SHAFT BEARINGS(new): OEM PORSCHE. 99911002900old#/91530239906new#. 356 50-59, 911 70-74. $240 These are $340.00 new from Porsche
    FAG Trans pinion bearing rear inner. 99905204300. 911 with 915 trans 72-86. $80 These are $120 new on ebay.
    TRANSMISSION MAINSHAFT BEARING(new): FAG 99911002500. 911 70-89. $80 These are $150 new on ebay.
    DIFFERENTIAL CARRIER BEARING(new): SKF 99905902700. 911 65-89, 912 65-69. $15 These are $27 new on ebay.
    TRANSMISSION DOG EARS(new)(2): 911 1972-1983. 3rd, 4th, 5th gears 915. PART NO 901.302.242.03. NEW. $100 each.
    TRANSMISSION SYNCRO RINGS(new)(2): 911 1978-1986. 1st Gear. PART NO 915.302.301.06. NEW. $80.00 each.
    DIFFERENTIAL OUTPUT SEAL(new)(3): Elring. 99911318340. 911 69-71 with magnesium pressure cast housing. 911 72-86, 912 1969, 924 Turbo 1980, 911 Turbo 1980. $10 each
    CRANKSHAFT REAR SEAL(new): Elring. 99911326440old#/99911342641new#. 911 78-86. $10
    TRANSMISSION MAINSHAFT SEAL KIT(new, some pieces missing): Elring brand. 99911318240old#/91530091100new#. 911T/E/S 70-73. $25
    CAM TOWER REAR RADIAL SEAL RING(new)(4): Elring. 35X47X7. 99911306850. 911 65-73, 912 65-69. $4 each or $10 for set of 4.
    VALVES(new)(2) ATE 3064 40mm 2.2-2.7Liter 1970-1977 Ex. Valves. $100 each. NEW!!!
    DOOR HANDLE RIGHT SIDE: 911. 1974-1989. Not perfect but nice. All there. 911531061/06200. $100
    TURN SIGNAL SWITCH(new): 91161330501. 911 1976-1989, Turbo-1989, 912E. NEW IN BOX!! SWF. $80
    ATE BRAKE MASTER CYLINDER REBUILD KIT(NEW): 90135593000. 911 65-77, 912 65-69, 914 70-76. $40
    VALVE COVERS: One set marked 1973.5 CIS. $70.00
    ENGINE CONTROL UNIT: BOSCH JETRONIC. 0280800055. 911SC 1982-1983 ONLY. Except turbo. $150
    INJECTORS (6 USED OUT OF RUNNNING 3.2): BOSCH 0280150158. 911 1984-1989 3.2, 944 ex. Turbo and 16V 1985-1988, 924S 1986-1988. $50.00 EACH. Or $200 for the set.
    HEADLIGHT SWITCH(2): (1)No knob. 91161302900. Old part number. 911, 1974-1977, 911T 1976-1977. $20
    VDO GAUGES COCKPIT(new)(3): TEMP/PRESSURE/TACH. NEW IN BOXES!! Some small corrosion on two. $20 EACH or $50 for all.
    METAL FOG LAMP GUARDS(6): (4) 5 ¾” round. Could stand a respray. $15 EACH. (2) 5- ¾”X 3- 7/8” outside. 4-7/8”X 2-7/8”. Could stand a respray. $15 EACH
    FUSE COVERS(2): One missing label. $30 EACH
    GLOVE BOX LAMP: 911.632.102.00.70A.M44 911 69-89. Used $40
    INTERMEDIATE SHAFT: (1) ONE gear 901.105.235.1R.(I believe this fits 1969 and up?) $100
    VALVE SPRINGS: (1) Full set for 1965-1973 911. Sealed unopened, OEM? PART NO. 901.105.901.00. See photo. $90.00
    OIL PUMPS (3) 2.2T Scribed 77703. $100
    2.4 Marked S.E.F. No drive shaft. $100
    2.4 Marked GFG or GTG. $100
    WHEELS: AMERICAN RACING. FRONTS ONLY. 16X8". $300
    OIL THERMOSTATS(2) X1 224 83 000 supposedly 150-160 degrees. 1971-1989?? Used in many 911's. $20 EACH
    Note: X1 248 83 000 supposedly 180 degrees.
    PISTON RING SET(new): GOETZE 90mm(1.5x 1.75x 4) (1974-1977 911S, Carrera 2.7). Goetze Part Number 08-319800-10. $80
    OIL FILTER COPPER GASKETS(6): 1198031B. Victor Reinz. 911 74-77, 914 70-76. $1 each or $10 for the set of 6. Will throw in other copper gaskets in other photo.
    CONNECTING RODS: Some complete, some missing bolts or nuts. $200 FOR ALL!!! Shipping will be high.
    (5) 911.103.105.OR S. JOSB KEX weight group. " " $30 each
    (4) 911.103.105.OR S. C 31597 29 weight group. (All complete) " " $20 each
    (2) 911.103.105.OR S. 31597 K 34 weight group.(One complete). " " $15 each
    (1) 911.103.105.OR S. C 31597 28 weight group.(Complete). " " $15 each
    (1) 911.103.105.OR S. 31597 20 U weight group. " " $15 each
    (4) 911.103.103.OR S. 23 31033 N weight group. 2.2S 1970-1971 $20 each
    (1) 911.103.103.OR S. 26 31033 O weight group. " " $25
    (1) 901.103.101.OR S. 5 H 30496 weight group. 2.0S 1965-1969 $30
    CAMSHAFT: 901.105.139.OR (LEFT) 1966 SOLEX!! I believe this is a VERY early or late cam as it is NOT a center oiler. $70
    I will take turn signal switch
    Sent PM w/ email address
    This post is almost three years old...now closed.
    Peter Kane
    '72 911S Targa
  1. Replies: 0
    Last Post: 01-14-2013, 07:10 AM
  2. Replies: 0
    Last Post: 12-03-2012, 05:04 PM
  3. LAST STASH OF VINTAGE EARLY 911 PARTS. NOS trans gears, seals, cams, S rods, etc.
    By velocejoe in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
  4. 2.7 L Parts Cheap! Crank, rods, cams, misc
    Last Post: 09-13-2012, 03:57 AM
  5. Parts Stash....
    Last Post: 04-11-2009, 07:32 AM
