Thread: 901 transaxle gearing and ring pinion combo question
    Hey guys, frequent lurker but infrequent poster. My project 912 is a bit of an odd duck to say the least which some may have seen around. Basically, I'm trying to change my final drive for higher speed freeway cruising. Right now I have the stock '68 901/902 5 speed. I've swapped in 3rd/4th/5th(ZD) from a 914. the ring pinion is 7:31 (4.29). with my 205/15 I am doing about 63 mph at 3000 rpm and for CA traffic, that's kinda slow but I get 30 mpg. as soon as i bump up to 3400 rpm it bumps me up to 75 mph but then i drop to 24mpg (and on boost as well). I have another good standard 901 4 speed in the garage a friend gave me and wondered if the ring and pinion that is found in the 4 speed sportomatic, 7:27 (3.857), would swap in? then i'd just put in a ZD 5th and be able to cruise at 75mph at 2900 rpm or 65mph at 2600rpm.
    68 912 - R inspired - 2.0L-4 turbo 18psi
    RGruppe #455
    S Reg #1539
    Oct 2008
    Burford, ON, Canada
    Sportomatic diff will not fit in a manual transmission.
    alright thanks. thats answered my question and guides my next steps
    RGruppe #455
    S Reg #1539
  1. 901 8:35 Ring and Pinion
    By gled49 in forum Technical Info
    Last Post: 12-06-2017, 10:05 PM
  2. FS 1972 911 7-31 Ring & Pinion with Speedo Drive Pinion
    By cog in forum For Sale: 911 Parts
    Last Post: 09-11-2012, 11:18 AM
  3. 550 NOS pinion ring 6:31
    By deejay in forum For Sale/Wanted: Other Porsche Cars and Parts
    Last Post: 12-23-2011, 09:03 AM
  4. 901 Ring & Pinion FS
    Last Post: 11-03-2008, 03:40 PM
  5. 8:35 ring and pinion
    By tfiv in forum Technical Info
    Last Post: 04-05-2006, 05:00 PM
