Results 1 to 8 of 8
Thread: H1 Screws
    Jun 2003
    Bend, Oregon
    H1 Screws
    This needs to come up every 5 years or so...
    I'm trying to figure out the type of screws that are used on H1's. I think that they're M4-0.7 x 6mm Phillips Oval Head Metric Machine Screw DIN 966A. Does anyone know for sure?
    JohnA
    Edit: These look like they might be coarse thread.
    Senior Member Cliff's Avatar
    Mar 2006
    8903one
    H 1 Screws
    Yes, John , I have a nos set with the screws attached. Will post a picture a little later tonite. Someone needs to mfg. some of these, because thy're correct & I think a little longer than what is usually used out there by most & have a rubber ferrule with a plastic washer to keep water out of the headlight bucket & moisture off the H 1 unit$$.
    Quote Originally Posted by jaudette3 View Post
    JohnA
    John, just to pik a nit here, the way you wrote the screw description is incorrect. When you state 'M4' that IS the diameter, the second # is the pitch, but I think your third # implied diameter. That should be the length. Your description would seem to indicate two different diameters. Just in case you'd like to know.
    Jun 2003
    Bend, Oregon
    Ed, I'm not familiar with the vernacular of fasteners. I just cut and pasted what was in my post from a fastener website without really understanding it. Thanks for the clarification - it's just what I was looking for when I started the thread.
    I'm still hoping to learn otherwise, but as far as I can tell, these screws are not available. It looks like the best option is to salvage screws from old H4's or somesuch.
    JohnA
    Mar 2006
    8903one
    NOS h1 attachment screw
    Here is the screw,ferrule & plastic outer washer on a set of H1`s..The ferrule is 1 cm long & the screw is 2.7/8 cm long....about 7mm inside diameter for the plastic washer. These are probably the later H 1`s if there is any difference!
    Just for the record John, which screws were you referring to, the aiming screws or the single screw that holds the unit into the bucket??
    No Phillips Head shown but here is start:
    http://www.mcmaster.com/#shoulder-screws/=l267n1
    PS: 10 minutes on a lathe and the deed would be done!
    Early S Registry #235
    rgruppe #111
    Jun 2003
    Bend, Oregon
    Originally I was interested in learning more about the adjustment screws - now I'm interested in learning about both.
    JohnA
  1. WTB: door screws
    By andrea70 in forum For Sale: 911 Parts
    Last Post: 12-01-2013, 04:21 PM
  2. Replies: 13
    Last Post: 06-05-2011, 02:26 PM
  3. Visor Screws
    By aturboman in forum Technical Info
    Last Post: 07-02-2009, 06:10 AM
  4. Sunroof Screws
    By chicagobreezz in forum For Sale: 911 Parts
    Last Post: 06-06-2008, 10:39 AM
  5. Air bleed screws
    By 72narrow in forum Technical Info
    Last Post: 10-10-2001, 03:57 AM
