Results 1 to 10 of 20
Thread: Oil cooler advice needed
    The engine-mounted oil cooler on my 67 911 appears to have developed a pretty good leak. A few questions: Is the reproduction sold through Pelican the customary fix? Can the cooler be changed without removing the engine? Any other suggestions? Thanks for your help.
    Don't know about the Pelican cooler, but the cooler can be changed with the engine in place (unless you have some other engine in the car,,,you didn't say otherwise) by removing the black metal plate at the top of the cooler, the side sheet metal piece, and the heat exchanger.
    All the reproduction coolers I've seen are garbage.
    All the aftermarket replacement coolers I've seen popped within a few thousand miles, and they are so poorly manufactured that they don't allow the removal of the #3 spark plug with the valve cover in place.
    I wouldn't hesitate to spend twice the cost of a new, reproduction cooler on a good, used original part (pressure tested and cleaned, of course).
    -Marco
    TLG Auto: Website
    remove cooler and send to pacific oil cooler for repair www.oilcoolers.com
    Do not be afraid to drop the engine, it takes an hour once you have mastered it.
    Apr 2004
    35,000 ft
    Quote Originally Posted by Mr9146 View Post
    +1...sage advice.....fix yours, don't buy a repro
    Jan 2007
    Portsmouth, RI
    +2...sage advice.....get yours repaired right by pacific oil cooler, don't buy a repro
    JohnB
    Reg # 1060
    Has anyone used the German made coolers from Sportwagen Eckert?
    Oct 2005
    Minneapolis, MN
    What Marco said...
    Aaron Hatz
    Flat Six, inc.
    www.flat6.com
    Follow us on Facebook
    www.facebook.com/flatsixinc
    Wow, not much doubt about what to do: I'll pull the cooler and send it out for repair. Thanks for the input; I really appreciate it.
    Update: I pulled the cooler out today. Holy smoke, that's a tight fit! It's off for repairs next week. I'll report back after it's reinstalled.
  1. Need advice on '69S front oil cooler
    By lopena in forum Technical Info
    Last Post: 03-21-2014, 02:28 PM
  2. 944 Wiper Mod advice needed
    By Andy B in forum Technical Info
    Last Post: 08-20-2010, 02:11 PM
  3. Please - ADVICE NEEDED - Please!
    By M491 in forum Technical Info
    Last Post: 09-02-2008, 03:13 PM
  4. Seeking Oil Cooler Advice
    By jaudette3 in forum Technical Info
    Last Post: 03-07-2008, 08:17 PM
  5. oil cooler advice
    By philip guiral in forum Technical Info
    Last Post: 02-10-2004, 09:23 AM
