Thread: 2.o to 2.3L Conversion
    Has anyone had a 2.0L rebuilt to 2.3 with the stock 66mm stroke? I spoke with a fairly well known shop that has a kit that requires the heads to be machined
    but not the case.
    My 2.0 is now 2.3 (2.25 liters with 85mm pistons) with 66mm crank; case was not bored. Ed Mayo performed the engine build.
    Paul Abbott
    Early S Member #18
    Weber service specialist
    www.PerformanceOriented.com
    info@PerformanceOriented.com
    530.520.5816
    I think it would be a good idea to fit a 2.2 or 2.4 head as well. The cam carriers should still fit and work correctly.
    My heads were replaced with 2.4 heads when I went from 2.0S to 2.25S...bigger valves.
    Paul Abbott
    Early S Member #18
    530.520.5816
  1. 3.2 Conversion ECU
    By CidTito in forum Technical Info
    Last Post: 07-28-2013, 03:47 AM
  2. Power brake conversion / de-conversion (1973 2.4E)
    By obrut in forum Technical Info
    Last Post: 12-13-2012, 02:18 AM
  3. 911 to 912 conversion
    By ren915 in forum General Info
    Last Post: 03-15-2012, 07:49 PM
  4. 86 3.2 Conversion kit
    By jpnovak in forum For Sale: 911 Parts
    Last Post: 06-24-2011, 06:18 AM
  5. 73 RS Conversion Kit
    By Rennman in forum For Sale: 911 Parts
    Last Post: 03-25-2007, 02:30 PM
