Results 1 to 10 of 10
Thread: Durant mirror, 105 or 130 on a swb 68s - discuss?
    Jul 2012
    Kent, UK
    I'm interested to know which mirror is correct for 1967 manufactured 1968 swb model?
    Thanks Rich
    Rich
    68 911S
    mbr. 2393
    Jul 2012
    Kent, UK
    The big one or the smaller diameter? I gave seen conflicting information about the switch from 105mm to larger 130mn
    Rich
    68 911S
    mbr. 2393
    Aug 2011
    Australia
    Hi Rich,
    My car 8/67 build has small diameter, also Rhd if that makes a difference.
    Sean.
    S Registry#2021
    My '68 911 Normal with a build date of 11/6/1967 has the large Durant.
    Jul 2012
    Kent, UK
    Thanks for getting back , I am interested to know if 68 swb model was the first year of the large mirror. In other threads on other body parts it has been suggest that the 68 model ended up a mix of parts between swb and lwb. My build date was 12/67 for 1/68 delivery
    Rich
    Rich
    68 911S
    mbr. 2393
    Dec 2010
    Tulsa
    They started delivering cars with the larger mirror in the spring/early summer of '67 - there was apparently some back and forth, though, and it may have appeared earlier in the US. My May build '67 has a large one, original as far as I can tell.
    Jul 2010
    Lisboa, Portugal
    Attention to the durant repros. Whith my mirror I can see everything excet the cars behind me. They're nice but useless.
    Cheers
    José Albuquerque
    1970 911 2.2 T Targa
    I believe the correct mirror for your car is the large Durant. You also may be able to see better out of it than you can with the small Durant as noted in one of the comments above. For anyone re-doing a car and using the small Durant, if you aren't hung up on going 100% original, you will find that if you mount it a little further back than the original stock position your rear view visibility will be much better.
    401(k) ('68 912) was purchased in the US Oct. '67. It has the large Durant mirror. I am the second owner.
    - Neil
    '67 911S (Ol' Ivory)
    '82 Hewlett Packard 34C
    Early 911S Registry # 512
    Senior Member rgrimm's Avatar
    Jan 2006
    Fargo, ND
    mine's the small, although I don't know my build date
    Roger
    68 Sand Beige 911 Coupe #11830091
    84 Moss Green 911 Carrera
  1. WTB: Durant Mirror
    By sam71TargaS in forum For Sale: 911 Parts
    Last Post: 07-30-2013, 12:02 PM
  2. FS: Durant mirror
    By ETW in forum For Sale: 911 Parts
    Last Post: 02-15-2013, 05:13 PM
  3. Wanted reflective mirror for Large Durant side mirror 71
    By aporschaguy in forum For Sale: 911 Parts
    Last Post: 12-02-2010, 04:26 AM
  4. Durant Mirror
    By Max (SD) in forum General Info
    Last Post: 05-13-2008, 07:38 PM
