Results 1 to 1 of 1
Thread: FS: 3.0 Liter Engine w 25k
    Thumbs up FS: 3.0 Liter Engine w 25k
    SOLD I have a 3.0 Sc engine for sale that just came out of my 69 targa. I have rebuilt another engine for the car so this long block is for sale. The engine was rebuilt by Bruce Abbot from Flat 6 Pac approximately 25,000 mile ago. It was a stock rebuild using Nikasil P&Cs that were within spec. A fresh valve job & the case was split with renewed parts as needed. Before removing engine, a leakdown was performed with less than 3% reported across all 6 cylinders. Besides changing out the oil with Brad Penn and performing regular valve adjustments, I have performed one update and that was to install pressure fed tensioners. The oil stays constant between changes with no burning at all. Slight drip from the lower left valve cover and the case seam is dry. I have used the Fan, fan housing & alternator on my current build. I do have stock SC heat exchangers, but there is no induction system. I was using PMOs but you can easily bolt on CIS injection. I was using crankfire ignition and that is available separately if you wish. Otherwise I will include an SC distributor. I was asking $5400 and open to reasonable offers. Here is a link to pictures...http://forums.pelicanparts.com/porsc...ml#post7226474
    please PM with more questions
    joe
  1. FS: 3.0 Liter Engine w 25k
    By joetiii in forum For Sale: 911 Parts
    Last Post: 01-23-2013, 05:42 PM
  2. Replies: 4
    Last Post: 09-24-2012, 07:24 PM
  3. Replies: 23
    Last Post: 08-30-2012, 06:01 PM
  4. Wtb - 2.4 liter engine
    By edl0944 in forum For Sale: 911 Parts
    Last Post: 07-28-2009, 03:41 AM
  5. FS: 2.7 liter engine
    By lechon in forum For Sale: 911 Parts
    Last Post: 05-09-2007, 05:53 AM
