Results 1 to 10 of 12
Thread: Any recommendations for Source of hardware: Nuts and Bolts
    Apr 2011
    N.Calif., south of SF
    Often I am wishing I knew a good source for the correct plated hardware for my cars. Anyone suggest some good sources?
    Haasman
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    Senior Member HughH's Avatar
    Dec 2004
    Melbourne Australia
    i would be interested as well - i am thinking about the need to "put some in stock" for the future, especially the yellow plated ones.
    if there is a good source it is then just a matter of how many of which sizes to stock up on
    Hugh Hodges
    73 911E
    Melbourne Australia
    Foundation Member #005
    Early S Registry #776
    I buy an assortment box from Wurth. Most Wurth distributors should be able to order these. It has all the right sizes of nuts, bolts, and washers for Porsche, and comes in a nice metal compartmentalized box. You can get them in untreated silver, or cad plated. For my Nylocks and crush washers, I get them from EBS.
    1969 911 E #824
    Sep 2006
    San Francisco
    I've had good luck with this site. Very fast shipping and they have a good assortment of the stuff we need. And I use these guys because they carry everything in yellow zinc.
    https://www.belmetric.com/
    Jeff Jensen
    Member kent olsen's Avatar
    Sep 2010
    McMinnville, Ore
    Are you just looking for metric? Lowe's and Home Depot have that.
    Kent Olsen
    McMinnville, OR
    72 911 upgraded 3.0L
    RGRUPPE # 104
    Jan 2012
    Green Mountains
    Mcmaster-Carr is worth a look. They have just about everything you need, and do carry some items in yellow zinc finish if that's important.
    Terrence Dorsey
    Senior Member maspirito's Avatar
    Jan 2013
    lexington,kentucky
    Bel metric is good but pricey
    check your local quick set they have a large assortment
    Dec 2011
    Victorville CA
    Jun 2003
    Bend, Oregon
    I like fasteners almost as much as I like tool kits. I've saved every screw, nut, bolt, washer, etc. that I've come across in the last 25 years. I've even picked them up off the street (I found a perfect undamaged H1 by the side of the road once, but that's a different story). When anyone in the family needs a fastener of any kind they stop by my shop and I usually have it.
    I've found Wurth to be a good source for bulk purchases. And our local Ace has an amazing inventory for onesies and twosies.
    JohnA.
    I have used Metric and Multistandard Component Corporation for 40 years. They have minimum order of $25, but you can mix and match quantities. Their fasteners are generally German sourced ( not Home Depot Taiwanese!) and available in raw steel, black oxide, clear or yellow Zinc. Great company.
    Mark Smedley
    '59 VW Typ I
    '69 911T 2.7
    '86 930
    '04 GT3
    '16 Boxster GTS
  1. Nuts and Bolts Kits
    By shipard in forum Technical Info
    Last Post: 04-25-2014, 11:24 AM
  2. Nuts and Bolts
    By Richardnew in forum Technical Info
    Last Post: 02-03-2013, 01:50 PM
  3. Specking nuts & Bolts 69 T
    By Marktodo in forum Technical Info
    Last Post: 12-16-2008, 11:42 AM
  4. wurth nuts and bolts
    By mike walker in forum Technical Info
    Last Post: 01-23-2006, 07:07 PM
  5. For the specialists: what brand bolts/nuts on the RS
    By GeorgeK in forum Technical Info
    Last Post: 04-03-2004, 10:36 PM
