Results 1 to 10 of 10
Thread: 69-73 Rear Wheel Bearings
    These parts seem to becoming difficult to obtain and prices are increasing.
    Over on the Bird they are around $76 which is quite expensive but typical of the prices I have also found in the UK.
    The size is 42 x 75 x 37 and they are Double Row.
    The FAG part number is 33 41 1 130 617
    By some happy coincidence they are also used as Rear Wheel Bearings on a BMW 3 Series E46 typical model year 2001. They may also fit other 3 Series types but I am not 100% sure.
    If you buy them from the BMW side of the site they are $36.00 each.
    $80 a pair is not a bad saving.
    Port Macquarie, Australia
    Fabulous info Chris!
    Just 3 months too late for me
    John Forcier
    EarlyS #1987
    Restoration Saga
    Feb 2011
    Surrey, UK
    Chris did you drop a '1' out of that FAG part no.?
    33 41 1 130 617 ?
    My Google search came up with nothing without the extra digit, and lots with it. Great info by the way ....
    Mick
    Mick,
    Unfortunately I did, but not deliberately and have now corrected the original post. GSF have them on line for £19.50 each including delivery and VAT. They are cheaper on line than buying from their store!
    Jan 2011
    DFW TX
    Thanks Chris. Pelican has also been out of stock on the $76 ones for a while now.
    Jan 2011
    DFW TX
    Chris, I wanted to thank you again for this helpful hint. I ordered the BMW E46 FAG bearings from Pelican and just finished installing them (and rebuilding rear calipers (thank you Eric for the PMB how-to), and fixing oil leaks, and repacking CV joints... ack) in the 914 and they went in perfectly.
    BTW they were FAGs made in Slovenia FWIW.
    Mike
    Aug 2005
    VA
    Just bought a pair of the FAG's and installed them over the weekend.
    www.AutohausAZ.com has them for $30 each. They also have a cheaper option.
    Chris
    73 911 E
    How difficult are they to install?
    Feb 2011
    Surrey, UK
    Quote Originally Posted by TZombek View Post
    Installing them is relatively easy - clean the bearing recess in the trailing arm, put the bearing in the freezer overnight and carefully drift it in using only the outer edge, not the inner race ..... or use a press if you have one.
    Getting the old one out is often a lot more fun. Lots of posts on here about how to build a simple cheap puller out of plumbing parts and a threaded bar. Usually you will trash the old bearing talking it out - never re-use no matter what.
    Do a search ....
    Mick
    Aug 2005
    VA
    Easier said then done. Second time doing it so learned from previous mistakes. A Sir Tool is extremely helpful to press out and in the old and new bearings. A trick to the trade. Get the hub hot and the new bearing will slide right in. Second trick to the trade, if excessive force is needed to get the bearing in or out somthing is wrong. Stop and figure it out.
    Let me know if you have any questions as it is all fresh in my mind.
    Chris
    73 911 E
  1. SWB Rear Wheel Bearings
    Last Post: 12-12-2016, 09:43 AM
  2. Rear wheel bearings - worn but no play?
    By Chris E in forum Technical Info
    Last Post: 05-16-2012, 05:10 PM
  3. FS: Rear wheel bearings '69 - '73 brand new SKF
    By m1franck in forum For Sale: 911 Parts
    Last Post: 01-16-2011, 05:42 PM
  4. Question regarding SWB rear wheel bearings replacement
    By buddeman in forum Technical Info
    Last Post: 06-25-2010, 07:19 AM
  5. 2 new SKF rear wheel bearings
    By 9seriesguy in forum For Sale: 911 Parts
    Last Post: 04-19-2010, 04:47 PM
