Thread: Teach me on Regulator Wiring
    Hello.
    Please teach me which cable go to the terminal of the regulator on '72 911S.
    I know the blue one got to the right terminal, the brown and black ones go to the same left terminal?
    Thanks advance.
    Takahiro
    Jan 2011
    DFW TX
    Brown is ground and goes to the mounting screw. Black is DF to the alternator goes to the screw terminal.
    If you'll look closely the left terminal is marked DF that stands for "dynamo field" and the black wire goes there. The blue wire is for the alt.warning light and of course goes on the only spade terminal. Brown is always ground in the German system so it goes on the mounting screw where the regulator is bolted to the relay board.
    edmayo
    Thank you for your input.
    Takahiro
  1. Window regulator
    By mike curnow in forum Technical Info
    Last Post: 11-14-2023, 06:22 AM
  2. FS: 73.5 nos warm up regulator
    By gled49 in forum For Sale: 911 Parts
    Last Post: 07-05-2013, 08:51 AM
  3. FS: 72 73 Warm Up Regulator
    By rick2 in forum For Sale: 911 Parts
    Last Post: 11-24-2008, 09:53 AM
  4. regulator
    By tryan in forum Technical Info
    Last Post: 11-20-2002, 05:45 AM
