Results 1 to 10 of 12
Thread: FS: 15mm wheel adapters (move Fuchs 7R offset wheels to outside.)
    SOLD.
    $150 plus shipping. These are the adapters used to position a 49mm/7R offset wheel properly in many early narrow body fenders. They fit my 74 narrow body perfectly, not sure about the earliest cars. Beautifully made by Schnell of Germany. Used once.
    Not appropriate for competition use without major Lock-tite.
    jhtaylor
    santa barbara
    less wing, more brass bxd's Avatar
    Mar 2010
    S.F. Bay Area
    Interested; are they adapters that bolt to the existing hub, or are they spacers that require longer wheel studs?
    Jordan
    rally-prepped '69 911T 3.0L
    S Registry #1933
    Vintage Parts & Restoration http://retro-sport.com
    Apologies. The ad was supposed to have a picture. They bolt to the existing hub, don't need longer studs.
    jhtaylor
    santa barbara
    Mar 2010
    S.F. Bay Area
    First in line as far as I know.
    PM sent.
    Jordan
    S Registry #1933
    PM sent around 8AM
    Craig Williams
    Eugene,OR
    Member #1070
    1972 911E Targa Puck
    I use the same (or very similar) bolt to bolt spacers with a set of 7R weld ups from Harvey Weidman. I have used them in auto-x competition with NO problem. Harvey had to clearance the inside of the wheel to allow room for the lug nuts that hold the spacer to the hub. You "may" want to take that into consideration. Not sure if these require that mod. Mine are flat 6's welded into 7R's and run on a 73 911. My bolt to bolt spacers are 15mm and 18mm.
    Bobby Smith
    member #299
    1973 914/4 2.8 ltr. (FTD winner 2008 Charlotte Parade) (sold)
    1973 911 "Orangello"
    1973 914/6 GT 3.2 "Crystal Blue Persuasion" (sold)
    2011 Boxster Spyder
    1973 911 E "E GO" Metallic Green
    These are what I use on my car as well. Makes switching wheels back and forth very easy.
    Tom
    Early S Registry #235
    rgruppe #111
    Tom
    Did you have any clearance issues with the lug nuts that hold the spacers to the hub on your 7R wheels?
    Craig Williams
    Eugene,OR
    Member #1070
    Not at all but I did listen to Harvey when it came to tire sizes. My car isn't lowered although I don't believe clearance would be an issue if it were.
    205/60 Rear. 185/65 Front.
    Tom
    rgruppe #111
    Tom, sell this car to me as quickly as possible to avoid further embarrassment.
    Your friend,
    Rick
    P.S. Always looking out for you pal!!!
    67 Normale, Old Rusty
    67 R Inspired and on a Diet
    73 T/ST Caged Beast
    RGruppe #383
    S Registry #739
  1. 7 x 15 Fuchs with 911R offset
    By eronbo in forum Technical Info
    Last Post: 08-02-2012, 05:58 PM
  2. 6 and 7(911r offset) x 16 Fuchs
    By Chris Pomares in forum For Sale: 911 Parts
    Last Post: 01-10-2012, 08:12 AM
  3. FS 15 X 7 Revolution Wheels (7R Offset)
    By joetiii in forum For Sale: 911 Parts
    Last Post: 07-04-2011, 07:31 AM
Tags for this Thread
