Results 1 to 2 of 2
Thread: FS: 3.0 and Italian Webers
    Senior Member Scotty B's Avatar
    Jul 2012
    Charles City Va
    3.0 engine I bought several years ago for a 914 project that is now gettign a Subaru swap instead. P.O. said it was running fine when he pulled it to put in a big bore he had built, but I am selling it as needing a rebuild as I do not personally know it's history. It turns over fine by hand, compression feels good while turning it over. I have NOT done a compression test or leakdown. I basically brought it home, took the CIS off for a friends VW bus project and put it in inside storage. Oil cooler and lines are not included. Exhaust is junk
    Used Weber 40 IDA's I got these already disassembled for rebuild. The only parts I can find that are missing are : 1 pump jet and bolt, 1 of the large top plugs, 1 air adj. screw and spring and 1 linkage bracket and drop link. I MAY be able to find these pieces locally if I have the time. Otherwise these are sold as is. Also includes new rebuild kits as seen in picture
    Webers=800.00
    Engine = 2000.00
    BOTH together=2500.00
    I would also consider knocking off some $$ for :
    a pair of NICE euro tail light lenses for a 914. Hella only, no repros.
    a pair of NICE euro tail light lenses for an early 911, black trim
    a set of good H4's for a 911
    a set of 930 flares
    I would rather not ship the engine, but can deliver to Hershey
    1973 911 RSR clone..... to be
    "And pretty soon you're grabbing gears like they are ten thousand dollar bills."
    http://www.kahikocustoms.com/auto-projects
    Jul 2012
    Charles City Va
    Carbs have been sold. Engine is pending payment
    Thanks all, Scott
  1. FS: 3.0 and Italian Webers
    By Scotty B in forum For Sale: 911 Parts
    Last Post: 02-03-2013, 05:12 AM
  2. FS 46 mm webers- italian made
    By TRE Cup in forum For Sale: 911 Parts
    Last Post: 07-31-2009, 03:56 PM
  3. 67 S on Italian e-bay
    By vipergruen in forum For Sale/Wanted: Early 911 Cars, 1965 - 1973
    Last Post: 04-16-2008, 08:44 AM
