New design for 2.0 litre con rods
And, will they be billet or forged?
Olivier.
PS: Email sent....
Hi Chris,
what average weight ( including ARP bolts & nuts)are you planning
JD.
Olivier,
Machined from a forged blank.
JD - 570g without bots - from 3D model and 630g with bolts.
Chris, Looks like it should be a strong rod but a little heavy compared to the stock 2.0 rod @ around 620g, and Pauter 2.0 rod @ 520g.
Mark Jung
MFI Werks
Early 911S Registry #972
Carrera T w/LWB, MT, RWS, PCCB
72 T 66 x 100 MFI Twin Plug Coupe
R Gruppe #686
Chris, does the 650g include the bearing shells? My stock rods, by no means the lightest (or heaviest) weight class, came in with a mean around 600g without bearing shells.
Weight of a rod is an interesting debate and H Beams are never going to be the lightest rod for a given design but they are strong in terms of twist and fatigue life.
Fistly let me say that I didn't type the weight with bolts correctly - Bolts are 30g each so weight with bolts is around 630. This may be a bit high as we have not allowed for the slightly lower density of the small end bush.
I think that the weight of this rod is about the same as a Carillo.
Looking at the basic weight groups the standard rods seem to weigh in at 560 for rod code 21 and 660 for Code 32.
I am not sure how well these rods perform at 8000 rpm in terms of life but I have seen many debates about early race engines needing 2.2S rods.
The weight groups of 2.2 S rods seem to vary between 700g for weight group 21 and 770g for weight group 32.
I am sure someone will comment about the reliability of the early rod.
I think that the Pauter design will always be lighter than an H beam and an I beam is also likely to be lighter.
The design philosphy of the rod seems to be the main issue
I think I understand the H and I design but what is a Pauter?
Pauter builds an updated version of the old X beam rod design. It has a rib up the broadside of the beam.
Mark Jung
MFI Werks
R Gruppe #686
HI will you be able to machine grooves to act as squirters at the main bearing end to allow cooling of the underside of the piston? Any ballpark price for rods??
