Results 1 to 8 of 8
Thread: '67 S Question
    Jan 2013
    Long Island, NY
    '67 S Question
    does anyone know the 67S have an aluminum cdi box?
    Feb 2007
    San Diego
    No CD on 65-68 cars, not on a 67 S either
    Feb 2007
    Cheshire, UK
    I think CDI was available late '68 model year as an optional kit but don't know exactly when (my guess is approx Jan-July1968); it appears as kit 901.602.010.00 in the "Repair Sets" section of the '65-'68 Parts Catalogue.
    Tim
    Early 911S Registry #1167
    Jan 2013
    Long Island, NY
    Thanks- I had read in one of peter morgans books the the 1967s started with the cdi's and did not see it on mine.
    Nov 2003
    Santa Monica CA
    The CD box's started on the MY1969 cars because the 67S cars would get sick from driving in stop and go traffic back in the day. Chris
    1. Chris-Early S Registry#205
    2. '70 911S Tangerine
    3. '68 911L Euro Ossi Blue
    Porsche recommended Delta Mk 10 or Sydmur Fireball CDs for non CD equipped cars. Sydmur has a steel box if I remember correctly and is somewhat rare, Delta is in aluminum and is pretty easy to find. 911s run better with CD ignition
    Jan 2013
    Long Island, NY
    How hard is it to put CDI into an original ignition?
    Thanks for your input- should I convert- I was told there is a 3 pin and a 5 pin aluminum box??? also how can I tell if I have the upgraded chain tensioners?????
    Mark
    Nov 2003
    Santa Monica CA
    67S can not use the pressure fed tensioner, so you would use the turbo with the wider idler arm. The only way is to remove the covers and inspect the tension ers Chris
  1. Replies: 5
    Last Post: 03-19-2015, 10:54 AM
  2. Question??
    By Minkoff in forum Technical Info
    Last Post: 05-14-2013, 07:34 PM
  3. Replies: 2
    Last Post: 07-13-2011, 07:15 PM
  4. 69S Man a question about yur Cab
    By tabs52 in forum General Info
    Last Post: 12-13-2004, 11:34 AM
