Thread: Cast Sway Bar Mounting Plates
    The sway bar mounting plates on ealry cars are a bit weak and need reinforcing.
    There are some cast plates around which are for the bodyshells with the wider seat pan but they are tricky to fit to the earlier shell an s ahev to be set an an angle from the vertical.
    just finished the patterns to produce some investment cast steel parts in the next few weeks.
    Fisrt batch of castings have just been delivered,
    They are investment cast from a low alloy steel and will be drilled and tapped in the next few days.
    Port Macquarie, Australia
    Well done Chris! They're over due...
    My car is road only, so the factory units will be fine; but I know the racers will appreciate these.
    John Forcier
    EarlyS #1987
    Restoration Saga
    Quote Originally Posted by Fishcop View Post
    Don't be so sure John. The road cars bust sway bar mounts, too. I once broke one going over an uneven surface in parking lot once...
    -Marco
    TLG Auto: Website
    Quote Originally Posted by Mr9146 View Post
    Well, I'm extra pleased these are available then
    John Forcier
    EarlyS #1987
    Restoration Saga
  1. 70S tub with factory roll bar mounting plates ?
    By RS-GT in forum General Info
    Last Post: 06-09-2014, 08:43 PM
  2. FS: Radio mounting and backing plates
    By yellow356 in forum Other Car Cultures
    Last Post: 02-27-2014, 01:01 AM
  3. FS: Radio mounting and backing plates
    By yellow356 in forum For Sale: 911 Parts
    Last Post: 02-26-2014, 11:16 AM
  4. Sway Bar Mounting Question
    Last Post: 12-10-2012, 11:31 PM
  5. Rollbar mounting plates $300 shipped
    By RPMClassic in forum For Sale: 911 Parts
    Last Post: 06-14-2007, 05:28 AM
