Just stripping down the 2.7 7R case engine that was in my 2.2S
I have pulled the heads off and they are dated 1/71.
Part number is 911 104 307 1r.
Are these the heads off the original 2.2S that was on the car?
Tim Pritchard
1970 911S (resto underway) http://www.early911sregistry.org/for...ge-1970S-resto
1976 Carrera 3.0 Group Sc Race Car
1969 911T Group Sb Race Car (Sold to a good home)
Where it says K1819 what is the last letter?
andy
67S in pieces
EarlyS: 1358
[SIGPIC][/SIGPIC]
Yes they are.
Are they still usable for 84 mm pistons or were they modified for 2.7 P&C?
Richard
The letters are K1819 H
Not sure if they have been modified.
The camshaft is 911 105 142 OR which I think is the 2.7S cam shaft.
Tim Pritchard
Just measured P & C and 90 mm, so the heads would have been modified.
Does this make them useless for a 2.2 set of P & C?
Tim Pritchard
Having checked with my mechanic, the outside diameter of the cylinder is the same for a 2.2 and 2.7. Therefore there would no mod required to bolt them on.
Can some one confirm that this sounds right please?
Looking at them they seem to be the same as one I have seen for sale in the past.
I am looking to keep them for when I build up my 70/71 2.2S motor.
Tim Pritchard
The crankcase cylinder bore for the 2.2 & 2.4 is 92mm. The crankcase cylinder bore was increased to 97mm for the 2.7 engine with the 90mm pistons/cylinders. So you would have to bore out the case cylinder bores in a 2.2 & 2.4 case to accept the later 90mm pistons/cylinders because of the outside dia. of 97mm on the cylinder bottom.
Mark Jung
MFI Werks
Early 911S Registry #972
Carrera T w/LWB, MT, RWS, PCCB
72 T 66 x 100 MFI Twin Plug Coupe
R Gruppe #686
Thx mark. I was thinking at the head end of the cylinder, which I believe has the same outside diameter for 2.2 and 2.7 cylinders.
Tim Pritchard
