Thread: FS: 1970-73 911S cylinder heads, matched set of genuine S heads
    Feb 2007
    San Diego
    This is a genuine matched set of 1970 911S cylinder heads. Part number 911.104.307.0R on all heads. Dates are 11/69 x2 and 12/69 x4. Intake ports are 36mm and they have the MFI injector port. They have been taken apart and cleaned, found no cracks anywhere. No corrosion in the combustion chamber, no broken cooling fins, really in remarkable great condition. Complete heads that should have a valve job and surface before they are run. These will work on most all 70-73 911S MFI engines but if you are worried about the dates that are completely hidden when the engine is together then they are most correct for 1970.
    These heads are a perfect upgrade for a 1969 911S where the valves are impossible to find, in conjunction with 84mm P/Cs you would have a 2.2S and it would run better, less prone to detonation.
    ($2000 plus shipping) PRICE DROP $1800
    Feb 2007
    San Diego
    pictures of the heads
    Feb 2007
    San Diego
    last picture
    Feb 2007
    San Diego
    bump for lower price
    Feb 2007
    San Diego
    these have been Sold
  1. Chambers of Cylinder heads 911S and 911E (1967-1969)
    By Elferhelfer in forum General Info
    Last Post: 02-19-2014, 09:57 AM
  2. 1970 911S Heads Rebuilt - $1,250
    Last Post: 08-01-2011, 12:35 PM
  3. 912 cylinder heads
    By Rick Cabell in forum Off Topic
    Last Post: 06-10-2009, 09:12 AM
  4. WTB 6 2.4 liter, 911S cylinder heads
    Last Post: 01-09-2007, 11:40 AM
  5. FA - 1967 911S Cylinder Heads
    Last Post: 01-22-2006, 07:00 PM
