Thread: Correct exhaust tip
    Correct exhaust tip
    Is the rounded or rolled edge muffler tip oem, or the squared off tip oem? and,,is there a varience for the 69-73 cars? I just bought a factory tip from Sierra Madre Collection and they commenetd,,,, you ordered the right one.
    RGruppe member 445
    Square tip is OE......
    Oct 2012
    ON
    John, which tip did you order? I have seen two offered and don't know which is correct, or maybe both. One is longer and has the back edge cut at 45 degrees while the other is shorter and cut at 90 degrees?
    Oct 2012
    ON
    Perfect. I couldn't at first figure out why that thread didn't come up when I did a search and then I noticed it was in the General forum, not the Tech where I did the search. Thanks.
    Thank you for the confirmations. I thought it was the squared and not rolled tip. Order placed for one with Eric.
    RGruppe member 445
  1. WTB: 2 x correct bolts for muffler/exhaust straps
    By Bantam in forum Wanted: 911 Parts
    Last Post: 06-04-2017, 07:16 AM
  2. WTB Correct Chrome Exhaust Tip, 1969 -1973 911
    By 69S-S/R in forum For Sale: 911 Parts
    Last Post: 10-15-2012, 10:05 AM
  3. Correct exhaust paint color on 72 911
    By Perry911 in forum Technical Info
    Last Post: 04-11-2010, 02:54 AM
  4. Correct heat exchanger and exhaust color -1966 Normal
    By 304065 in forum Technical Info
    Last Post: 10-23-2008, 06:38 AM
  5. advice on correct exhaust color 1972 911T
    Last Post: 10-21-2008, 03:47 AM
