Thread: leaking fuel line
    leaking fuel line
    I have a 73.5 that I can not seem to get the fuel line that connects to the fuel pump to stop leaking. It is leaking from the end closest to the engine. I installed a new line and after a few days starts leaking again. I noticed Stoddards has 6 and 9 mm line. Which is the correct size? Also are there clamps that work better than others. Thanks
    just a thought.
    are you sure its the line and not the pump?
    old mfi pimps are prone to leaks at the O-rings.
    not sure if thats true of your car.
    bob moglia
    '72 E sunroof coupe
    73.5 is CIS, not The MFI of which I believe you are referring to, Bob.
  1. Need help sourcing a fuel line
    By BlackC4 in forum Technical Info
    Last Post: 05-07-2013, 03:50 AM
  2. PMO fuel pressure control unit - return fuel line?
    By lkadams in forum Technical Info
    Last Post: 05-27-2012, 05:58 PM
  3. WTB MFI fuel line banjo
    By budge96 in forum For Sale: 911 Parts
    Last Post: 03-26-2011, 10:43 AM
  4. braided fuel line
    By tull in forum Technical Info
    Last Post: 01-20-2011, 07:31 PM
  5. Fuel Line
    By kissov356 in forum Technical Info
    Last Post: 06-26-2006, 12:45 PM
