Results 1 to 10 of 11
Thread: Correct air box for a carbureted 71T?
    Hello,
    I found this two metal air boxes, one has a regular fitting on the back and the other one has a T fitting, my car came with Weber carburators and I am trying to find out which one its the correct one, also it's the correct snorkel the long one with the hose fitting at the end?
    Thank You.
    Aug 2009
    SF Bay Area
    The top one is for carbs. The bottom one is for MFI
    Jim
    To add to Jim's I.D. all cars with a charcoal cannister (70-73) would have had the 'T' fitting. The small end is for the cannister vent hose.
    I am a little confuse now, my 71 it's a US version and I think it did come with that canister up front, so the correct one will be the T fitting?
    Jan 2011
    DFW TX
    Let me add to the confusion... Your 71 T probably had Zeniths originally. It probably had a plastic air box in 71. The top one you show is for carbs no tank vent. The lower one is for MFI because it has the cold start fittings. You can use either but likely neither is 100% correct.
    Snorkel sounds right.
    Wauuu....I new that in 71 some came plastic and some metal but that neither of this is the 100% correct one? That sure add to my confusion, I hope some one can post a correct picture of the one I need,I don't want to go wrong on this one.
    My car is a California delivery 71T. It came with a plastic air cleaner. Here is a photo. Name:  engine 2.jpg
    1969 911 E #824
    Great picture thank you! Did it com with Webers?
    Thanks, I just finished the engine build. No the car came with Zeniths, but during the build, I switched to Webers. I am much more familiar with Webers, and I couldn't seem to get the Zeniths to run right. The back of the housing does have the T fitting in place. As far as correctness goes, the 71 T's came with both metal and plastic air cleaner housings. Since the COA would never say, it's really anybodys guess which is correct for your car. As with all Porsche models, the factory used up what parts they had in the bin first, before switching to the replacement part. It would probably be safe to assume that early build date 71's still had metal, and later build date 71's switched to plastic.
    1969 911 E #824
    Great info thanks!
  1. FS: Airtex Inline Electric Fuel Pump for Carbureted 911
    By m1franck in forum For Sale: 911 Parts
    Last Post: 01-10-2014, 08:30 AM
  2. Factory air cleaner for carbureted engine
    By John Z Goriup in forum For Sale: 911 Parts
    Last Post: 07-20-2011, 05:14 PM
  3. Replies: 3
    Last Post: 05-05-2011, 01:23 AM
  4. Replies: 1
    Last Post: 02-11-2009, 07:16 PM
  5. My CoA- it's almost correct!
    By 72tii in forum General Info
    Last Post: 12-02-2006, 02:36 PM
