My rs has an antenna on the passenger, but it is manual and it should be automatic. I was lucky to find the oem power unit. The spring activated toggle switch to the right side of the steering column is there. I went to the Pelican site and downloaded the Porsche PET, but could not find anything that shows what parts are needed and/or how it is wired. I am trying to find something that shows how the wiring was installed, if there is a relay (probably not) and where is ties into a fuse or the fuse panel.
Thanks for the help.
