Thread: Workshop pages- Air distribution levers and their cables placement
    Apr 2011
    N.Calif., south of SF
    In my restoration of the dash area: facia covering, radio replacement etc I remove the air distribution lever assembly. I am curious about the cable adjustment(s) at the levers.
    Anyone have factory repair manual pages on this or share some links/ wisdom etc. I've located the correct cables to the correct corresponding control lever, but I am not getting the cable sheathing correctly lined up.
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    70 914-6 #9140431874
    73 911s #9113300709
    I don't recall that manual covers this very much, if at all. The important part here is to make sure the sheath at both ends is secure, other wise the cable won't move. Adjustment is done by leaving hoses off so you can see what the various flappers are doing so you can adjust the cable length correctly.
    Apr 2011
    That's a good tip. Thanks
    Haasman
    Registry #2489
    R Gruppe #722
    65 911 #302580
    73 911s #9113300709
  1. Sunroof cables needed
    By rpsurfr in forum For Sale: 911 Parts
    Last Post: 05-11-2011, 03:56 PM
  2. FS - Sunroof Cables
    By tgittens in forum For Sale: 911 Parts
    Last Post: 06-23-2009, 07:20 AM
  3. Handbrake Assembly w/ two small levers
    Last Post: 06-23-2006, 11:52 AM
  4. PCNA Distribution Center Tour
    By RC70SCoupe in forum General Info
    Last Post: 04-09-2004, 10:19 PM
