Thread: 2.0 to 2.3 Build Plan
    More than Original
    Jun 2004
    SoCal
    I wanted to run the specs of my planned upgrade to a 2.25 from a 2.0 by the experts and get some opinions on compression ratios.
    The case is an Al 2.0 with all the oil upgrades, 66mm crank, std rods and bolts, recently rebuilt no issues. Mahle cylinders bored to 85mm and JE pistons with CR of 9:1 to 9.8:1 not sure? Rebuilt 2.2/2.4 heads to S pecs ported and polished 46/40 valves 36/35 ports. Running L cam (same as E) topped off with Webers. In conclusion a 2.2 with "S" P/C and heads with an "E" cam.
    My first thought is to run a CR of 9.8:1 same as the 911S. But I want to ensure that's the best choice with 91 octane street gas in CA. JE Pistons offers a 9.8:1, 9.5:1 and a 9:1 option.
    TIA
    Bret Davis
    1968 911L
    Senior Member BURN-BROS's Avatar
    Sep 2003
    Camarillo, Ca.
    Bret,
    The Dynamic compression of the E cam is higher than the S, that is why the E had less static compression than the S. Stay below 9.5 /1 with the E cam. 9.0/1 would be the safest route.
    Aaron Burnham
    Burnham Performance
    1071 Avenida Acaso ste D.
    Camarillo, Ca. 93012
    805-240-6931
    _________________________
    mad scientist
    Apr 2007
    Austin, TX
    Overall this sounds like a great build.
    In my opinion that intake port size might be too large for that cam and displacement. I think the low-end would suffer more than you would gain in the top-end. If the car is primarily street driven I would err on the small port size to increase intake velocity. This will also help the metering signal on the webers. My numbers would be a 33-34mm intake diameter and this would close to max out the intake velocity at peak TQ and HP around 100 m/s gas speed.
    YMMV.
    1971 911T SWT - Sun and Fun Machine
    1972 911T - "Minne" painted and undergoing assembly.
  1. Need you help to choose resto plan
    By Xavier PJB in forum Technical Info
    Last Post: 12-10-2012, 12:04 PM
  2. Help plan our U.S.A. Holiday
    By classic in forum Off Topic
    Last Post: 06-18-2012, 12:53 PM
  3. My parents plan to sell their -65 911 (Finland)
    By janski in forum General Info
    Last Post: 03-12-2012, 12:45 AM
  4. Project Plan A
    By Paul Schooley in forum Technical Info
    Last Post: 10-28-2006, 11:00 AM
