Thread: Very early spring plates and covers
    I have just removed a set of very spring plates from an early car and the spring plates and covers look just like those fitted to a 356C.
    Does any one know if these were ever used on 911s as the covers fit and the spring plate bolts up to the trailing arm.
    This is as was used on the 1964 cars, and I checked photos - it was still in use on a April 1965 car, I'm thinking it was standard
    Bob
    Early S Reg #370
    I took them off a February 65 car so they may be correct. - Thanks
    The corresponding rubber bushings should be found in an early VW Beetle stock if not available from Porsche stores
    356C used short torsion bars and covers with no central hole. 356A and B used long torsion bars. You can use a 911 cover and longer bushing to upgrade 356A and B.
  1. Spring Plates
    By Gumby in forum Technical Info
    Last Post: 04-11-2014, 09:48 AM
  2. SWB spring plate /SC spring plates swap
    By smedley in forum Technical Info
    Last Post: 01-06-2014, 04:02 PM
  3. FS: Early suspension covers/plates
    Last Post: 07-28-2012, 12:13 PM
  4. FS: Early Spring Plates
    By NickP in forum For Sale: 911 Parts
    Last Post: 11-14-2008, 12:04 PM
  5. Spring Plates?
    By gymmoe in forum General Info
    Last Post: 09-20-2005, 11:05 PM
